Question about Emerson Fans CF929BS Midway II Ceiling
Remote midway II does not run
Have checked remote battery, wall switch is on, circuit breaker is on and that remote/receiver frequency match. The unit has been operating as needed for over 2 years. Neither the light or the fan will operate.
  • 25 Answers
Disassemble your fan and check the two terminals of power inside the motor maybe the wires were the problems that is why neither your fan nor ligth is on.
Posted on Apr 16, 2009
Is there a default dip switch setting that Harbor Breeze fans are shipped with? My parents got a new remote control for their 56” Exeter 134743 but it isn’t working. They are elderly so getting on a...
The hand control is made to a set frequency to match the fan remote receiver. If the Fan receiver frequency is different from that of the hand controller, it won't function.
Now, if the match was perfect, the other reason the hand control may not work, is if the wall switch was not turned on for the fan to run or light to go on.
Feb 18, 2018 | Dryers
Fan will not turn on since wall switch was turned off then on.
Try changing the frequencies on the transmitter & receiver. If that doesn't work, you probably need a new receiver. The wall switch has to be in the on position for the remote to work.
Oct 11, 2014 | Hampton Bay Dryers
My Hampton Bay UC7083T stopped working after having to reset the breaker it is connected to. The remote battery was changed and the dip switches double checked. I cannot turn it on using the wall switch...
Try putting a different frequency in the remote transmitter & receiver. If that doesn't work, you probably need a new receiver. You have a low-end store brand fan made from low-end parts. Remember, you get what you pay for.
Aug 19, 2014 | Dryers
Set up remote on harbor breeze
Check the frequency on the receiver & transmitter to make sure they match.
Mar 29, 2013 | Hunter 52" Ceiling Fan With Light And...
Directions to reprogram hunter 952g
You need remote control.
Go to your circuit breaker or fuse box, and turn off the power to the fan you will be programming.
  • 2 Turn the fan's remote control over, and remove the battery compartment cover. Take out the remote's 12-volt alkaline battery, and set it aside.
  • 3 Match the DIP switches inside the remote's battery compartment with the DIP switches on the fan's receiver unit.
  • 4 Reinsert the 12-volt alkaline battery into the remote's battery compartment, and replace the battery compartment cover.
  • 5 Go back to your circuit breaker or fuse box, and turn the power to your fan back on.
  • 6 Press the "Hi," "Med" and "Lo" buttons on the remote control in quick succession. Complete this step within 20 seconds of completing Step 5. The remote is now programmed and ready to operate your fan.
  • Sep 06, 2012 | Hunter Dryers
    Monte Carlo ceiling fan and light not working
    Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
    Lastly, there always is the possibility that some gremlin changed your original control setup.
    Jun 23, 2017 | Dryers
    Fan was running on Low, we left the house for about an hour, when we returned the fan was off. Fan does not work, nor do the lights. We even tried new batteries in the remote and the circuit breaker. We...
    remove the ceiling cover cap , and check for power at the unit in the ceiling box, if you have power there, go to the switches on the unit, check the wires coming out of the switches, if you have power there, your motor has probably died , but before you give up all hope, disconnect the remote receiver, and check the same items with the receiver out of the loop,, be careful,, the fan may just start up !!
    Jul 20, 2011 | Hampton Bay 52 In.Carriage House II in...
    I have a Liftmaster 3265-267, remotes do not work. Tried new batteries in remotes and still no work. When I get close to overhead unit and depress remote, I do hear a couple clicking noises
    If the door works from the wall switch, but not from the remote, I'd suspect the battery. (s)
    Since you have NEW batteries that only leaves 2 things that can be wrong. Check the program numbers for the remote and the door control board. They need to match.
    If you check that and the remote still doesn't work, it could be the receiver built into the circuit board of the opener. Hopefully it's not that since it would need to be replaced.
    Make sure the batteries aren't old one that were in a drawer somewhere, that despite being "new" are dead....or weak.
    Feb 07, 2011 | liftmaster Chamberlain Garage Door Opener...
    Ceiling fans on same frequency
    There should be dip switches in/on both the remote control and the ceiling fan that enable you to change the control frequency. The only thing that you have to ensure is that the two components are set to a matching frequency.
    The switches in the remote are located in the battery compartment just above the batteries. Remove the dome on the ceiling fan and you should find the switches for that unit. Just compare the two and match whatever changes you make from one unit to the other.
    Originally answered by d0n0r in this question
    May 25, 2009 | Universal Remote Control Hampton Bay...
    WE LIVE IN A CONDO AND SOMEONE IN THE COMPLEX HAS A hAMPTON bAY CEILING FAN WITH A REMOTE JUST LIKE US. wE MUST BE ON THE SAME FREQUENCY AND WHEN THEY TURN THEIRS ON IT WILL MAKE OURS COME ON WHEN WE HAVE...
    Feb 18, 2009 | Universal Remote Control Hampton Bay...
    Emerson Fans CF929BS Midway II Ceiling Logo
    147 people viewed this question
    Top Emerson Fans Dryers Experts
    Are you an Emerson Fans Dryer Expert? Answer questions, earn points and help others
