Question about McCulloch Garden
Top plate filing angle for a MoCulloch Pro Mac
What is the top plate filing angle for a MoCulloch Pro Mac 10-10. Is it 30 or 35 degrees. If not what is it.
  • 42 Answers
This all depends on the chain that you have on it. a person can buy any angle chain for most saws. you will need to figure out what chain you have to see the right angle. sorry i can't help more.
Posted on Mar 15, 2009
How do I miter with my radial arm saw (RA-2500). I can't tell from the manual.
the slide can be angled by the degree plate where the timber sits
the blade can be angled by the degree plate on the arm that mounts the saw
so you can get a 45 degree to the timber length and a 45 degree angle cut to that angle to give you a corner mitre cut
Jul 03, 2017 | Saws
How to replace the throat plate spring
This can be tricky. At a 45 degree angle push the top spring under the holding area of the machine. Hold this spring firm and push down on the second spring. Rotate the throat plate simultaneously until the plate is in its correct position.
Aug 13, 2015 | Sewing Machines
What is thesharpening angle for mac cat 330-839 chain
25 - 30 degrees looking down on top of the chain.
Drop the handle end of the file no greater than 10degrees.
If the chain has been sharpened more than 3 times please check the "height" of the "raker" in front of the chain tooth on the chain.
As a general rule these rakers have to be lowered to allow the cutting edge of the tooth to "bite" deeper.
Aug 29, 2014 | Garden
File size sharpen angles
91sg ( hobby chain ) needs a 5/32 file, the top plate should be 30 degrees
Nov 21, 2013 | Poulan 16" 38cc Gas Chain Saw P3816
Filing angle for Husqvarna chainsaw 450 --20 ' bar chain 72 links?
On .325 pitch chain the top plate angle should be 25 degrees, there is normaly a match mark on top of each cutter, the depth gauge should be set at 25 thousands of an inch.
Apr 02, 2013 | Husqvarna 450 Chain Saw 18 Inch Bar...
A scalene triangle has side measuremnts a=43, b=55, c=30 . Angle a plus Angle b must equal 43. Angle b plus Angle c must equal 55. Angle c plus Angle a must equal 30.
Answer: angle a=9 degree angle b=34 degree angle c=21 degree Explanation: we have, a+b=43............(1) c+b=55..............(2) c+a=30..............(3) from (3) we get, c=30-a...........(4) substituting value of c from (4) in (2) we get, 30-a+b=55.........(5) a+b=43..........(1) (5)-(1) give 30-2a=12 30-12=2a a=18/2=9 degree giving value of 'a' in (1) 9+b=43 b=34 degree similarly giving value of 'a' in (3) c+9=30 c=21 degree
Oct 14, 2012 | TOPICS Entertainment Snap! Geometry...
What size file should I use ona Husqvarna 137 chain saw?
The question you ask is dependent on the chain in use not the saw that drives it. To determine what chain is installed we must see the chain. A local seller/mechanic should be willing to answer your question. Lowes will not know!!!
Excerpt from "How To Sharpen a Chain Saw" here follows:
http://www.grounds-mag.com/mag/grounds_maintenance_sharpen_chain_saw_2/
Use the right tools
If you're holding it correctly, a proper-diameter round file simultaneously restores the three different angles of a saw-chain cutter. Different-sized chains and different cutter styles call for different file diameters. It is vital to use the right size file.
In general, 1/4- and 3/8-inch-pitch, low-profile chains call for a 5/32-inch file; 0.325-inch-pitch chains require a 3/16-inch file; and standard 3/8-inch-pitch and 0.404-inch-pitch chains demand a 7/32-inch file. Beware, however, because many exceptions exist. For example, some brands of standard 3/8-inch-pitch chain require a 3/16-inch or 4.5-mm file. Check your chain-saw owner's manual or saw-chain instruction sheet to determine the correct file diameter. If you're not sure, ask your dealer. He also may have literature showing the proper filing angles and special procedures for your chain.
Getting the angles exactly right is not as important as removing all damage from the side plate and top plate and making sure the critical top corner is really sharp. However, for good results, you must consistently hold the file at the correct height and orientation within each cutter. This is difficult to do without some type of file guide.
Like most tools, simpler is better when it comes to file guides. The best guides are plates that drop over the chain. These keep the file at the right height and attitude and have witness marks to show proper top-plate angle alignment. The best thing about this type of guide is that you can see what you're doing. Guide plates that clamp to the file and rest on the cutter top plate also are good, but they tend to obscure your view of the cutter. Whichever guide you select, make sure you get the right model for your chain.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 15, 2010 | Husqvarna Garden
Cutting 45's on my Dewalt 744
Narrow throat plate should work. Sure you have the blade installed correctly with arbor washers?
Feb 28, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Mcculloch pro mac 5700-20 what is the angel to sharpen chain
The angle to sharpen most chains is 60 degrees for the top angle and 30 degrees on the tooth of the cutter.
Aug 27, 2009 | Saws
Garden Logo
120 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
