Question about Gateway (4000782) Motherboard
I cant get the HDD LED to work... yes it is hooked up right...
I cant get the HDD LED to work... I ordered another board and I have the same problem. I tried using gateway's factory power switch/LED connector with the same result. Can anyone tell me why the HDD LED pin on the motherboard won't come on?
Fast Ed
  • marked3010 Mar 05, 2009
    I know that LED's work like any other diode, that is, current can only flow in one direction... The Pin on the motherboard that should supply the signal is not working... Thanks for trying!
    Scholar:
  • 67 Answers
Some of the wires going from the power switch, reset switch, speaker, and LEDs must be attached to the motherboard the correct way. That is, they must not only be placed in the right spot where they need to go, but they also must be connected with positive and negative wires on the right pins.
If your HDD LED is not lighting up when the HDD is "thinking", try reversing the cable where the HDD LED wire plugs in (just flip it so the black wire is where the non-black wire was). I tried to find a good picture of your motherboard to guide you but they were not very helpful. From squinting really hard, I believe the spot they should plug into the board is by the CMOS battery. There might be printed words on the board surrounding the area to connect them that tells you which two pins are for the HDD LED.
Posted on Mar 04, 2009
I need the wiring diagram for emachine model D6405
Usually it is in very small print right on the motherboard next to the pins, use a flashlight and/or a magnifier to see what order the pins go in. The hard drive light will say HDD, power will say PWR, etc.
Nov 26, 2011 | E-Machines eMachines Desktop PC
HOW TO HOOK IT UP WIREING THE LITTLE PLUG UP FRONT HD LED PW RESET ETC
Here is a few pictures that shows you how to connect your cables:
I am not sure which one it is, but these are the most common ones.
Hope this was helpfull.
Mar 17, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have a hp pavilion a1777c desktop. i had to take it apart to replace hdd and dvd rom and some other parts. i have been trying to get detailed info on where the front power panel wires connect onto the...
There is usually a set of pins on the corner that are labeled get a magnify glass and light up the board take the glass and look down on one of the corners it is usually on the right corner of the bottom of the board at the bottom of the desktop case. You will usually see a series of abbreviations. LED, HDD, PWR, RES or RE the pins are marked. Now on the wires to the power button you will see the same wire abbreviations. Just hook up the HDD wire to the HDD pin the PWR to the PWR button wire and so on. RESET wire is RE or RES etc. Those really are the only three you will need. Not sure of the exact abbreviations. But they are lettered enough for you to match them. The best thing to do is try to download the board specs and get a look at the pins one side is neg and the other is positive it would be to your best interest to find the mother board specs for you mother board since you went all over the internet and could not find the board specs. just match the LED and the others they are marked PWR is the main and HDD is just showing when the HDD is working. The reset is for the button to reset the computer. It is basic and not that complicated really. Thanks for using FixYa! John
Mar 02, 2011 | Computers & Internet
Cant seem to get right the pin connection on the morther board for power,hdd.
One corner of the motherboard will have a grid of pins.
Two adjacent pins will be labelled 'PWR' or 'POWER'.
Two adjacent pins will be labelled 'HD' or 'HDD' or 'HD LED'.
Dec 20, 2010 | Computers & Internet
E-Machines T2642 PC Desktop from mother board 3 cables came unplugged 1 is green pwr led 1 is pwr s/w-black ,one is red hdd led i just need to know what order to plug them back in
Sorry you are having trouble.
Led's have a + and a - side.
With a magnifying glass you should be able to see where each one goes on the board. Start with pwr s/w. when you have it on the right pins then you can push the button and turn it on. I have done with with a screwdriver and quickly touching two pins at a time until it comes on.
Next the power LED. This one should be on all the time.
Last id hdd LED. This one will only be on when HDD is active and reading or writing.
The connector you are looking for is normally in the right hand corner opposite the power supply and has all the wires from the case going to it.
Apr 05, 2010 | E-Machines T2642 PC Desktop
Unpluged HDD LED PWR S/W and PWR LED for board
it's usually written in fine print beside pins. Failing that get the manual which tells you
Feb 26, 2010 | E-Machines T3958 (827103050974) PC Desktop
Led pins on Tyan Tiger S1834
http://www.starlino.com/data/remote_pc_switch/images/front_panel_connector.gif
try here hope this helps...
or download the manual from this site
on the page 15 is the configuration
Feb 01, 2010 | Computers & Internet
Motherboard wire hook up I pulled the wires : Power LED, Power SW, H.D.D. LED off the motherboard, don't know the pattern to put them back on.
its simple, start from left power led next to power led is power switch, just below power switch put hdd and next to hdd put reset . thats it done.. all boards have the same module.....
Nov 24, 2009 | Computers & Internet
My motherboard vt8235 I cant figure witch order they go
i'm guessing your talking about your power LED, HDD LED, reset button etc.? Look closely on the board, there are small hints printed on it. eg... pwr, reset, spkr etc. and on the colored wires, there ought to be printed reset, power etc. just match them and plug them in. you can't do too much damage if they are wrong.
Jan 04, 2009 | Computers & Internet
Gateway (4000782) Motherboard Logo
331 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
