Question about Canon Rebel XT / EOS 350D Digital Camera
When taking photos at a basketball game and with my setting on the sports setting my pictures are coming out blurry and out of focus. How might I correct this?
  • Larry Lee
    Larry Lee May 11, 2010
    Go to Aperture setting and set it to the smallest number (largest opening) to let in as much light as possible. The sport setting assumes you have plenty of light which you don't at a basketball game indoors. The disadvantage to the small aperture number is a small depth of field (DOF) so if your picture problem is solved by the small aperture number and you don't like the small DOF then one step at a time increase the aperture number until a compromise is reached. Basketball photos are a know difficulty setting.
    Problem Solver:
  • 17 Answers
Does the background look blurry? I suspect what you are getting is called motion blur. You need a faster shutter speed, which is either possible by having more light in the room or a faster lens.
If you want to try to get the best shot (with your existing equipment) possible of sports under low light conditions you may have to set some controls manually.
Use the Av mode, and set the Av number to the smallest one possible.
Adjust the ISO by pushing the ISO button on the back and setting it to the highest value (note: this results in a "noisy" picture, you will sacrifice color and see some specks in dark areas)
Set your frame advance to continuous by pressing the button on the left of the circle and setting it to the one that looks like multiple pictures.
And set your focus to "AI Servo" by pressing the "AF" button to the right of the circle and choosing "AF Servo".
Then shoot away.
Let me know how that works.
Posted on Mar 16, 2009
When I take a picture it always comes out blurry. How do I correct this?
Search Results
    The Top 4 Causes of Blurry Photos, And How To Fix Them ...
    www.digital-photo-secrets.com/.../the-top-4-causes-of-blurry-photos-and...
    Out of focus An image that is out of focus will appear blurry. ... The first is to increase the shutter speed as explained above, The second is to hold your camera steady whileyou take the shot. .... It's always very helpful, and I enjoyed the video.
    Why Do My Pictures Come Out So Blurry? « Samsung Galaxy S3
Nov 30, 2015 | Cameras
Picture comes out blurry
There are three main reasons for blurry pictures.
Pictures may come out blurry if they're not focused properly. If some objects are sharp and others are not, this may indicate focusing on the wrong subject. This is usually not a major problem with compact point&shoot cameras since they have such a wide field of focus that almost everything will be in focus anyway.
Subject motion. If moving objects blur while stationary objects remain sharp then the shutter speed is too slow to freeze the motion. Try switching to the sports mode, and/or add more light.
Camera motion. This is the most common cause. Set your camera on a table or other stable surface and use the self-timer to take a picture. Take another one while holding the camera. Compare the two on your computer.
Feb 22, 2012 | Canon PowerShot SD870 IS Digital Camera
Basketball game pictures are blurry
basketball game is a fast moving object which is hard to take the picture perfectly sometimes
always using a flash, or external flash for more lighting support, set the shutter at about 1/80 or faster, ISO setting is 400 to avoid darker result, the Aperture should be set at the biggest number such as f 1,4
hope this advice help you
Dec 20, 2010 | Nikon D60 Digital Camera
Why are my pictures coming out blurry?
Pictures may come out blurry if they're not focused properly. If some objects are sharp and others are not, this may indicate focusing on the wrong subject. This is usually not a major problem with compact point&shoot cameras since they have such a wide field of focus that almost everything will be in focus anyway. However, make sure the macro/far switch is set to the appropriate position for your picture.
Jun 12, 2010 | Vivitar ViviCam 8025 Digital Camera
After taking pictures it come out blurry
1) Make sure all settings are set to "Auto".
2) The picture button has 2 stages, it takes a little practice, but after a while you can feel them.
The first stage tells the camera you're about to take a photo so get to it, setup the focus and set up the exposure setting.
The second executes the photo.
3) What you have to do is pause between stages 1 and 2 to give the camera a moment to focus properly. Then continue with taking the shot.
4) The other thing which can cause blurred photo's is camera shake, try and hold it as still as you can.
Mar 06, 2010 | Nikon Coolpix S210 Digital Camera
Canon rebel xsi, using 75-300 lens, taking photos of basketball game, pictures are blurry, especially the ones in "action" using the sports mode. also tried my 18-55 IS lens, same thing happening, using...
That's a big lens and for sports photography you are going to need a lot of light to ensure you can use a fast shutter speed to capture the action. Sports mode may do too much for you and you might want to try switching to a more manual mode. Try switching to Tv mode which gives shutter speed priority. Set the shutter speed to something around 1/150 or higher (1/200) which should be fast enough to freeze the action. Make sure the ISO is set to 200 or 400 for best results and see how you get on. This should stop any action based blur which would leave you with focus problems if the pictures are still blurry. Check out http://www.dpreview.com/reviews/canoneos450d for info on what this camera can really do for you
Jul 28, 2009 | Canon EOS Rebel XSi Digital Camera
I was at a basketball game last night and taking pictures with the d80 and the 55-200 lens. All of the pictures I took in auto focus were blurry. I changed it to the S mode with shutter speed at 4000 and...
Hi and welcome to FixYa.
I could go into a long disertation about your camera settings and what you should use, but I should let Ken explain it. I read this a couple of months ago (because I love photography too)! He has some good ideas, tips, tricks and really has the D80 dialed in. You can read it here.
http://www.kenrockwell.com/nikon/d80/users-guide/d80-users-guide.pdf
Good luck and have fun with your camera.
Rob
Feb 28, 2009 | Nikon D80 Digital Camera with 18-135mm...
Blurry pictures
Just returned from trip to Cuba..most photos taken outside and few inside...all photos were exc. or good except the ones I used with the telephoto feature. Had I left it on the W feature,these photos would have been ok...also make sure the focus ring lens adj. is not on the macro imaging feature..found that focus ring lens setting sometimes moved when I put the camera into its case
Pancho-poppa..
Feb 10, 2008 | Jazz DV-179 Digital Camera
Canon 70-200mm f/2.8 IS lens not focusing
I have had to replace the focusing servo motor is these before. The problem of seeking without locking in may mean the same for your lens. Do check for a dirty filter on the front and look to see if the rear optic is dirty or cloudy first. I'm assuming other lenses work fine on your camera.
Jan 05, 2008 | Canon EF 70-200mm f/2.8L IS USM Autofocus...
D50, blury pics
Blur can occur if the shutter speed is too low relative to the degree of movement of your subject(s). While the 'sports' mode favors shutter speed and adjusts the focus for moving subjects, you may still need to increase the ISO (I'm not sure the camera does that automatically), or use flash, if feasible.
Alternatively, try panning the camera with your moving subject. This should blur the background, but keep the subject from blurring.
Finally, keep in mind that in sports photography, blur is sometimes a desired outcome that produces a sense of motion in an otherwise static photo.
Hope that helps.
Nov 14, 2007 | Nikon D50 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
188 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
