Computer is on but in constant standby mode and won't boot up
Gateway 500s computer
  • jrcolbert
    jrcolbert May 11, 2010
    If you reboot the machine does it come back up to the desktop? are you just wanting to know how to turn off standby by mode? Sorry for the questions, but this is all I see... "
    Computer is on but in constant standby mode and..."Just need some more info.
    Have you tried actually unplugging the power cord from the back of the machine. if there is a light on the back of the power supply let it go all the way out. Then plug it in and turn it back on.
  • 530 Answers
Hi im in cebu phils.may i gelp you? friend if it happens try to chech your memory if it is seated properfly and firmly. try also check your hardisk connections and the processor connections. be sure you connected all the wires neede in your mainboard. thats all hope i helped you.good luck
Posted on Mar 04, 2009
  • 4 more comments
  • Joseph Baculan
    Joseph Baculan Mar 04, 2009
    hi im in cebu phils.may i gelp you? friend if it happens try to chech your memory if it is seated properfly and firmly. try also check your hardisk connections and the processor connections. be sure you connected all the wires neede in your mainboard. thats all hope i helped you.good luck
  • Joseph Baculan
  • Joseph Baculan
  • Joseph Baculan
  • Joseph Baculan
    hi im in cebu phils.may i gelp you? friend if it happens try to chech your memory if it is seated properfly and firmly. try also check your hardisk connections and the processor connections. be sure you connected all the wires neede in your mainboard. thats all hope i helped you.good luck.
  • Joseph Baculan
How to turn off safe mode?
When booting up computer constantly tap F12. until you get a boot selection screen.
At that point use the arrow key to make sure start windows normally is selected, and hit enter.
That will knock it out of safe mode. if by hitting F12 you do not get to the boot selection screen, then shut off the laptop, unplug the charger, wait 10 seconds, and then turn the computer on, and the menu should appear.
I hope this was helpful!
Jan 26, 2014 | Gateway Computers & Internet
SAYS IT IS IN STANDBY MODE
your best option is to remove the powercord from the back of the computer and wait a minute before plugging it back in and turning on your system this will delete the "standby mode save" and turn on your PC normally
Dec 12, 2013 | Gateway GT5656 Desktop PC
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
I am getting same issue is this resolved?
Press F8 as the computer boots up, when you get a Windows menu option select LAST KNOWN GOOD CONFIGURATION and then press ENTER.
If that doesn't work boot up and press F8 and select SAFE MODE and press ENTER.
Aug 27, 2009 | Gateway 7330GZ Notebook
Gateway MX6927 Windows Xp won't boot
put your xp disk in the optical drive.Turn off computer. Turn computer back on as soon as you turn it on start tapping f 12 constantly.it should go the boot menu giving you a choice of booting from cd or hard drive choose boot from cd.Be sure you choose repair rather than new installation or you could loose all your information stored on the hard drive,I personally would try safe mode first you can get to safe mode by tapping f 6 when you first turn on your computer.
May 04, 2009 | Gateway MX6927 Notebook
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
Gateway 400SD4 Power Problem
Faulty Battery.
Get a new one.
If that is not the problem check the ram.
Jul 01, 2008 | Gateway 400SD4 Notebook
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
