Question about Daewoo KOR-63DB Microwave Oven
The plactic that covers the holes is through is destroyed
Daewoo KOR - 63F7
There are a holes in the vieving screen in the door the. The plactic that covers the holes so light can pass through is destroyed in one of the holes. Can I still use the microwave or will microwave energy pass through? What can I do to fix it?
MicrowaveSvc
  • 9011 Answers
SOURCE: How to change light Daewoo KOR - 63F7
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Posted on Aug 20, 2009
Wiring diagram for daewoo kor 860a
May problem of microwave oven model.kor-861h is not working fan&heater but ralay&digital display working so what is damages sir?
May 02, 2012 | Daewoo KOR-860A Microwave Oven
Not a problem. I just want to know where to find the wattage for the microwave oven. It is a KOR 1N0A
The Daewoo KOR-1N0A is rated at 1,000 Watts with a 1.1 cubic foot capacity. The manual and documentation are available from the Daewoo site: http://www.daewooelectronics.co.uk/daewoo-product.aspx?folderguid=0039D237-8626-41AE-9D67-8F347C0C3B26&listguid=D897DFDF-A16E-452A-BB1A-7544B98F24DD . The links for these are near the bottom ot the page. If the direct link doesn't work, start at http://www.daewooelectronics.co.uk/daewoo-products-details.aspx?folderguid=DD695DCA-E930-41AC-BD76-1F59753A64B1 and then search microwave and then the model.
I hope this helps.
Jan 31, 2011 | Daewoo KOR-1B4H Microwave Oven
My DAEWOO KOR-1B4H. BLEW A FUSE WHEN I OPENED THE DOOR. CAN I FIX IT MYSELF?
which fuse has blown, was it in the plug or in the microwave itself?
Feb 17, 2010 | Daewoo KOR-1B4H Microwave Oven
Aug 19, 2009 | Daewoo Microwave Ovens
Hi i have a micowave model number is KOR 63F7
You can download your owner's manual here.
Jan 18, 2009 | Sunbeam SBM1000 Microwave Oven
User manual
Download the manual here:
http://www.nodevice.com/user_manual/daewoo/microwave_oven1/kor-630a.html
Sep 29, 2007 | Daewoo KOR-630A Microwave Oven
Daewoo KOR-63DB Microwave Oven Logo
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
