Question about Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
THe dishwasher will not start.
The cycles are out sync on my Bosch dishwasher.Seems like it was opened in the middle a cycleand the machine will not start.What do i do to reset it?
  • 27 Answers
What cycles does your dishwasher offer? there is a cancel reset. its usually holding scrub and econo wash at the same time while the power is on will activate the cancel drain mode then reset the dishwasher next time you power it. if that doesnt help then let me know your full model number and i will tell you exactly which buttons to press.
your model should read:
SHU66C05UC/??
what numbers are ??
Posted on Mar 19, 2009
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
Jan 06, 2014 | Bosch Evolution 800 SHE58C02UC 24 in....
Unable to turn off the delay start and the latch is in the wrong position so that the door will not close properly. Also, there is no digital display--it remains dark. I tried the cancel/drain, which...
Pull the open handle to open the latch up and try to get it to close. Disconnect the power to the machine for a few minutes. Run a cycle that you don't usually run. See if that helps.
Nov 02, 2009 | Bosch 24 in. SHV66A03 Built-in Dishwasher
Bosch Dishwasher will not power on
I saw my repair man do the following, which you might try...
Open the door and simultaneously press & hold down the power button with the 2 buttons used on your model to "Cancel & Drain." If the unit comes on it now is in self-diagnosis mode. Release the buttons and close the door. The unit should start to fill with water. Press the power button to exit the mode.
Jun 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHU3300 dishwasher stuck on hot water intake (w/ no power)
It sounds like the fill vlave is stuck open. This can happen if your pressure is low or if the machine is old. I would start by replacing the vlave.
May 12, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
First unplug it for a minute or two then try it. If still the same just let it go through whatever cycle it wants to - to complete and then try it again.
Mar 26, 2009 | Bosch 24 in. SHU42L05UC Stainless Steel...
Dishwasher starts but never seems to come out of wash cycle
Check to see if the unit is heating. Open the door mid cycle. If the unit doesn't heat then the unit cannot advance to the next step in the programme. it is basically waiting to reach temperature which it won't if the heating element or thermostat has blown. Hope this helps.
Jan 05, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Our bosch diswasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display. What does this mean?
Hello zeviemail
Welcome
You said, your Bosch dishwasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display.
What is your model number and the year of the dishwasher?
Oct 04, 2008 | Bosch Dishwashers
Bosch WFMC2100UC Washer stops in mid-cycle
Hi, it seems its about time to replace the motor carbon brushes.
Thanks
Aug 31, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch Dishwasher
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
DON'T FORGET TO RATE
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher Logo
537 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
