Question about HP Pavilion a350n PC Desktop
I have a noise coming around my driver side front wheel,only when i hit a small or big bump i drive a toyota echo 2000, i replaced the strut ( mount not sure) ball bearings along & sway bar( was loose so had it replaced).my airbag light is on, not sure if it has anything to do with that. noise sounds exactly like the sway bar is loose but tight,
  • 51 Answers
This Is A Web Site For Electronics Not Cars.
Posted on Mar 03, 2009
Thumping noise coming from right front wheel well?
IT is probably the strut bushing that is worn, The one that you can't see
Oct 18, 2015 | Dodge 2011 Grand Caravan Crew
Front driver side suspension knock over bumps
See if you can bounce car and replicate the noise. If you can, you should be able to find it, and put your hand on it. Stabilizer bushing are a place to look, both at the lower a arm and on the frame. If you narrow it down to the strut, it will need to be replaced. The front trans mount also goes bad, try putting it in drive with your foot on the brake and give it some gas and see if the engine moves an excessive amount.
Nov 23, 2009 | 1992 Buick Regal
99 camery solara...ratlingnoise front left wheel,
Strut tops are a common failure on the 97-01 era Camry/Solaras.
They will make a hollow rattle sound whenever you hit bumps or uneven pavement.
They can be replaced one at a time, and do not require strut replacement if your old struts are still in good shape.
Replacement does require a strut compressor and an alignment afterwards, placing it outside the scope of most do-it-yourselfers.
It is labeled "suspension support" in the following diagram. The bearing below it is typically replaced at the same time.
Sep 14, 2009 | 2004 Toyota Solara
2000 escourt zx2 left front end clunking noise when hitting bumps or letting out the clutch in 1st gear .Ball joints and springs/struts have been replaced.
have u looked at the top mounts allso could be gearbox or engine mounting allso is it front wheel drive could be drive shaft joints
Aug 21, 2009 | 2001 Ford Escort ZX2
2000 Lexus ES300 - 45K miles. While driving over small bumps, the right front strut and sometimes left front strut makes a rattling noise as if something is loose. I have also heard same rattling noise...
NO YOU NEED TO REPLACE THE STRUTS MOUNTS AND THE BEARINGS UNDERNEATH IT. THE STRUTS ONCE THEY GET AGE ON THEM THE RUBBER THAT QUIETS THE BUMPS WHILE U DRIVE START BREAKING A PART. SO JUST REPLACE THE STRUT MOUNTS AND BEARINGS. NOW A WAY TO CHECK THE STRUTS R TO GO EACH SIDE WHERE THE WHEEL IS AND PUT YOUR HAND ON THE FENDER OR THE TRUNK AND PUSH UP AND DOWN REALLY HARD THEN LET GO WATCH TO SEE IF THE CAR KEEP SHAKING OR STOPS. IF IT SHAKES THAT STRUT IS BAD. IF NOT THEN U R GOOD. ALSO IT GOOD TO REPLACING 2 FRONT SEPRATE OR TWO REAR NOT ONE AT A TIME DUE TO ALIGNMENT ISSUES. GOOD LUCK
Jul 11, 2009 | 2000 Lexus ES 300
Noise in right front wheel or dsah board
The solution is the upper strut mounting plate. To fix it you need to take out the strut tower and take apart the strut. The faulty part is the plate that has the 3 studs that actually mount the top of the strut to the frame. You may want to also plan on replacing the strut as well, when i took mine apart, the strut piston wouldnt go back into the strut body, that means its shot. Also if one side needs this done the other probably does too. The upper strut mount is about 20 bucks only from a dealer and the strut is about 60 from any auto parts store. hope this helps
May 22, 2009 | 2000 Volvo S40
I have a noise coming around my driver side front wheel,only when i hit a small or big bump i drive a toyota echo 2000, i replaced the strut ( mount not sure) ball bearings along & sway bar( was loose so...
check your wheel well plastic that goes underneath the fender... i had the same problem a couple days ago and i notice that the strut was hitting plastic.. either screw it back on or tuck it in somewhere..
Mar 03, 2009 | 2000 Toyota ECHO
87 Audi Coupe - Clunking Noise
the car is aging
there are other bushings and ball joints to make noises at that speed
the top rubber mounts failed for a reason
if i were on that job i would have replaced both gas struts
at the same time....
not much structure to the top strut mounts
see pictures in link
Strut Mount Early Small Chassis Audi Density Line
Mar 08, 2017 | 1987 Audi GT
Front end noise
I have the same problem and it is the strut and maybe mounts (depending on how bad it is)
Jun 23, 2008 | 2002 Toyota Camry
HP Pavilion a350n PC Desktop Logo
159 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
