Question about Nokia 1600 Cellular Phone
My nokia 1600 backlight wont turn off
MY nokia 1600 back light wont turn off, even when i take the battery out and put it back in. I turned the phone off and even then the back light still stays on. What can i do to stop this?
5 Suggested Answers
SOURCE: nokia 5800 backlight problems
On a computer install the nokia software updater which is included on the CD in the box. Perform a software update to the most recent version and this should solve the problem.
My phone had this problem (after having it for around 4 months). After performing the update the issue was resolved, hope this helps
Posted on Jun 13, 2009
SOURCE: Nokia 1600 Screen blinking and phone not functioning at all
1600 flash files
Posted on Jan 12, 2010
AnnamMaha
  • 106 Answers
SOURCE: Backlight continually on.
UEM damaged, change UEM
may be there is something short, may be uem?
well , UEM is assuring 2 Voltages Input to the LCD : Vio , Vflash if they are present then UEM is not Faulty ...
Posted on Jun 02, 2010
raingamj
  • 2148 Answers
SOURCE: My phone work well but backlight doesn't light up.
Posted on Aug 12, 2010
SOURCE: My nokia 1600 looses signal
my 1600 ufone signal is so week n other network signal is ok.what is problem?
Posted on Jan 08, 2011
MY MOBILE IS NOKIA 1600 BACKLIGHT IS OFF, HOW TO BE POEN
go to setting menu> display setting >you will get backlight setting just turn it on .now your problem is solved
Feb 18, 2011 | Nokia 1600 Cellular Phone
Nokia 1208 will not turn on
press red button on your cell 1min.
May 27, 2009 | Nokia 1600 Cellular Phone
I was chaging setting and I turned of backlight
If its just the backlight then you can stay in a well lit area and look at the screen that way to change the setting, also you could try plugging it in to keep the backlight on.
May 19, 2009 | Nokia 1600 Cellular Phone
The keyboard and screen light don't work
nokia 1600 display blank thi is my broblem
Feb 14, 2009 | Nokia 1600 Cellular Phone
Nokia e51 wont turn on,notification light comes on but nothing on the screen
same here. the phone has not had any major problems for 10 months. I was on the phone when there were two separate incoming calls. I hang up and call the first one. Hang up once again, open the phone book to make a new call. The phone got stuck in the phone book, backlight became very strong. It was like this for 5-10 seconds, until i took the battery out. Now it won't "boot". The backlight, notification light and the ******** indicate that the phone turns on, but it doesn't continue from there.
I
Oct 12, 2008 | Lands Phones
3230 keypad lights...
This is just because the settings of display are not right. got to your phone's display settings and adjust the display backlight setting to 15 seconds or 10 or whatever.. If its still not fixed then you may have to update your phone's firmware..
May 31, 2008 | Nokia 3230
Nokia1600 repairing
hi there sir must go to your nearest service center to replace your LCD it must be damage already. the light of that phone was built-in to the LCD display. and that is why also your keypad doesn't have light cuz' it is series to the display light.
ok!
peace!
Mar 30, 2008 | Nokia 1600 Cellular Phone
Sony ericsson k800i
Try removing the memory card (assuming you are using one)and battery overnight. On the following day put the battery back in (don't put the memory card back in if you are using one) and try turning on the phone. If this doesn't solve the problem then a reflashing of the phone's firmware is required. Good luck!
Dec 10, 2007 | Nokia 1600 Cellular Phone
Phone wont turn on or charge
try another battery in ur handset or ur handsets battery in other handset u will find where the exact problem is ? for more support contact nearest service centre
Aug 13, 2007 | Nokia 1600 Cellular Phone
Nokia 1600 Cellular Phone Logo
315 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Prashant  Sharma
Prashant Sharma
