Question about Onkyo HT-SR800 System
PS 3Not connecting to HDMI
Hi. I bought a PS3 recently but cannot get anything on my HDMI channel.
I thought it could be a shoddy cable that came with a bundle set for the console so I bought aally high spec one but got results.
Someone told me there are a couple of types of HD and that the PS3 doesnt work on one of them!!?? Not sure if this is true.
My TV is BUSH and has one HDMI socket. I have never plugged anything else into the HDMI.
Can you help?
    Problem Solver:
  • 4 Answers
You have to go into the video settings and set it up for either HDMI, or analog (red and white) that came with it when you bought it. I had the same problem, maybe this will help. I went from a HDMI tv and then tried to connect it to a regular tv. Couldn't read the menu screen, so in the directions, you can "reset" the PS3 by holding down the on/off button and listen for two beeps, that should get you video back to go into the settings between different tvs. Hope that helps.
Posted on Jun 25, 2009
  • JX3 JOHNSON Jun 25, 2009
    Ooops, forgot to include the center speaker too in my last reply...I am set up speaker wise for 7.1 and so is the receiver. It is a package from Onkyo.
    Problem Solver:
  • 5 Answers
Connect the PS3 using another cable then go into the menu setup and make sure that the resolution is set to a level your tv can handle. Start with 480p and go up from there. I would imagine BUSH (never heard of it) isn't the highest quality tv so you have to make sure it can handle the signal. Start with that.
Posted on Mar 04, 2009
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Feb 26, 2009 | Samsung Televison & Video
Surround Sound works with DVD, but not with TV, cable, etc.
dont know if it helps,but try connecting audio cables to the dvd from tv. worked for me !
Jan 05, 2009 | Sony DAVHDX265 System
Ps and TV not connecting using av cable
when you turn on the ps3 hold the power button till the system beeps
Nov 15, 2008 | Sony PlayStation® 3 (60 GB) Console
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
No sound for my ps3
There's a set-up menu in your ps-3, you have to change the menu from analog to digital output.
Kind regards, Gerard
Oct 19, 2008 | LG 42LC2D 42 in. LCD HDTV
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
40gb hdmi
I had the same problem at first. I did the following:
1. Connect both cables: Multi-AV and HDMI.
2. Go to the TV's channel for SCART.
3. You now can see the PS3. Go to Display Settings, under
Settings menu. Select HDMI and the desired resolution.
4. Change to the HDMI channel.
5. You should now also see the PS3's XMB on the HDMI channel.
6. You can now disconnect the Multi-AV.
I hope this information can help you and your customer.
Please rate.
P.S. I figured you were Dutch since you used Neophyte as a name for your previous question. Are you Dutch, and in that case: what videogames store you work at?
Greetings,
DarkNeogen.
Jan 30, 2008 | Sony Playstation 3 (PS3) Console
HDMI connection
Check ur video input on ur tv dude,make sure it says hdmi in yop corner,and not svideo or anything else but hdmi
Aug 27, 2007 | Sony Playstation 3 (PS3) Console
Onkyo HT-SR800 System Logo
188 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
