Question about PANDIGITAL 8.0" Digital Photo Frame (PAN802)
Cannot get my photos from memory stick to progess beyond the 1st 5 photos. they keep repeating. I never had a manual.
  • 423 Answers
Hi there.
1st) How did you put the photos on your stick? Did you load them from a computer, or did you load them off a camera?
If you loaded them off a camera, did you format the card before you took the pics, or before transferring them from the camera's internal memory? You have to do format the memory card from the camera menu before it will work properly.
If you used a computer, same thing, you need to format the stick before you transfer photo's to it. Try it and let me know.
Posted on Mar 03, 2009
I have a renault megane expression 04 plate. I was given the code 0087 for serial number 8200256141TA747. I have tried to put the code in but using the buttons on the radio but I can't get it to...
0087 is the correct code
IF THERE IS NOSTEERING WHEEL CONTROL , THEN USE THE PRESET BUTTONS ON THE RADIO Press the First Preset Button repeatedly for the 1st digit to be displayed Press the Second Preset Button repeatedly for the 2nd digitto be displayed Press the Third Preset Button repeatedly for 3rd digit to bedisplayed Press the FourthPreset Button repeatedly for 4th digitto be displayed Then press and HOLD Preset button 6 for 10 seconds to store your code (Note :Some radios use Preset Button 5 to store the code )
Apr 11, 2011 | Car Audio & Video
How to transfer pictures from computer to camera memory card?
Below is how to transfer your photos incomputer to a memory stick in Windows XP operating system 1. Insert the memory stick into a compatiblememory stick reader. Plug the memory stick reader, with the memory stickinserted into it, into the computer's USB port. 2. After a moment, a screen thatsays "Removable Disk" will pop up and prompt you to take an action.Click on "Open folder to view files using Windows Explorer." Thiswill open the folders on the memory stick. Select and open the folder whereyour photos are stored. 3. With the memory stick folderand the photo folder open simultaneously, use the mouse to click-and-drag thephotos to the memory stick folder. 4. Close all folders and removethe memory stick reader from the USB port. 5. To ensure that your photos havebeen transferred, plug the memory stick back into the USB port. When the"Removable Disk" screen pops up, select "Open folder to viewfiles using Windows Explorer." Once you see the photos on the memory stickfolder, you can close the folder and remove the memory stick reader from theUSB port.
Jan 08, 2011 | Fuji FinePix J10 Digital Camera
My memory stick does not work on my sylvania 10' digital photo frame
1st of all please check ur memory stick whether it is locked manually or from a software by putting it to a nother suitable camera or anything which suites for the stick.
if the stick still works when u put it on the other camera the fault is in ur came. if so take a nother memory stick and put it in to ur camera and check whether it works??? den please reply.i'll give the solution when u reply. thankyou!
Nov 13, 2010 | Sylvania Cameras
How to upload photos from my computer to my sandisk stick
1. 1st go to the folder where you have the photos bring this up as a window and then minimize it by clicking the minus sign in the upper right side of the screen.
2. Insert your Sandisk usb stick into one of the USB port located either in the front of you desktop/ laptop or the back. The USB stick then should be detected by the Windows Operating System.
3. Now that the Operating system has detected the USB memory stick select the stick and then right click and click "new folder" a folder will then be created ( name the folder what you want it to be ) so that you will be able to find it when locating you data.
4. Now maximize the folder that you have the photos on and go to "edit" at the top left hand side of the window and on the drop down menu and select "select all" then select "copy" then minimize this window
5. Go to the Sandisk window and maximize it. Then right click and select "paste" this will move a copy of all the photos that you selected in the location where your photos are stored and transfer them to the Sandisk flash drive. That's it! you have now a copy of the photos to your portable drive.
I hope this helped. Have a great day!
Aug 27, 2010 | Computers & Internet
Hello, My parents purchased me a digital Poloroid photoframe and i have downloaded my photos onto it but it keeps sticking and wont move on to the next picture. Also there is about 6 photos which are...
My first thought would be to format the entire memory. Then put the pictures on a couple at a time and see how they work.. It's possible that the coding on a couple of the pictures is corrupt and that would cause the type of symptoms you describe..
Beyond that I'd return it to the shop as it should be straightforward to set up and use..
Hope this helps.. :-)
Oct 06, 2009 | Polaroid IDF-1030 (826219006783) Digital...
SP 6000/PS6000E-207PK-EN Will not fire up. If press start, then LEDs flash Orange (1st left) 5 times then 2, then 1 and then repeats. 3rd LED (green) stays on. If battery is removed, start button pressed...
You got some short on board, You need techguy. Or possible Bios flash, Remove the Harddisk and press the power button.
If nothing change, Remove power, battery, cd rom, Hdd, memory.
Then put one stick of memory, power up, see anything comes up.If does, power off, put the other memory plug in power, fire up.
If does ok. Then plug off, and put hdd without CD rom. see if it did work.
If none is worked as I say you have short or CPU fan is not functioning.
Aug 17, 2009 | Toshiba Computers & Internet
Sony Cybershot - the memory stick is full
More than likely the camera still thinks the photos are on the stick, especially if you deleted the images while it was hooked to the computer. I would safely move the rest of the photos off the stick onto your computer then format the card through the camera and with the camera disconnected from the computer. this should clear the card.
Feb 03, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Saving game data in my psp
well there might be a fault in your game disc or u need a new memory stick duo 2g and up
Dec 31, 2008 | Sony PlayStation Portable (PSP) Console
My Pictures just vanish!!!
Yes, you are possibly to recover the lost photos with so-called photo recovery software. Well, since you failed to mention the OS you are running, I'll recommend you have a try of Wondershare Photo Recovery, a program equipped with both Windows and Mac versions. For Windows OS, download from here. If you are running Mac OS X, get the program from this link.
Step-to-Step Instruction:
1. Download and install the trial version on your computer, then connect your camera memory card to the computer (I assume you are using Windows). Start Wondershare Photo Recovery and select the drive letter that assigned to camera memory card.
2. Then choose the file type (all, photo, video, music) click "Star Scan".
3. Now the scanning process will start automatically to look for the deleted items. You will then get a list of all recoverable ones.
4. Preview the photos. If your deleted ones are found, then you need pay to get the activation code. And click "Recover".
1. Take the free trial version before you buy.
2. Before your deleted items are recovered, do not take more photos or videos.
I hope you good luck,
Jan 04, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Taking still photoes with the memory stick.
1. Set the mode switch to MEMORY STICK. 2. Set the power switch to CAMERA. 3. Press the PHOTO button and hold it. **If you do not wish to keep the still photo, wait 2 seconds until the picture releases. 4. To keep the image, pess the PHOTO button once again within 2 seconds after releasing the button. The still image is recorded to the Memory Stick. **Audio cannot be recorded onto the Memory Stick.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
PANDIGITAL 8.0" Digital Photo Frame (PAN802) Logo
266 people viewed this question
Top PANDIGITAL Photography Experts
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
