Question about Delta & Single Handle Shower Faucet
I installed Delta shower faucet 132900 and I could not shut the water. What did I do wrong?
  • bert_lavoie Mar 03, 2009
    I'm sorry but I didn't give you the whole story.
    When I finished installing the faucet, it worked ok. Then I had to shut off the feed valves because there was a small pipe leak in the back. I fixed the leak and I put the water back up. To my surprise I could not stop the water in the shower.
    I shut the valves to the shower. I took the front of the faucet apart: the plastic cover to control the water in the shower, the hot and cold control. I did not remove the cartridge.I only took the front apart. I put everything back together and turned the water feed valves on. To my surprise I was able to shut the shower water off. Everything was ok.
    What the devil happened. I didn't do anything different and I fixed the problem. Can you explain that? If you can you're a genious. I called Delta and they could not give me a response. I'm just afraid that if I shut off the hot/cold feed valves again I'll experience the same scenario.
    Thank you very much in advance.
    Problem Solver:
  • 4 Answers
Did you solder the valve in? If so you may have got it to hot. Or debris could have gotten in the valve. Turn the water off, remove the handle and cartridge. Check cartridge for damage or debris
Posted on Mar 03, 2009
  • Robert Savage Mar 03, 2009
    It probably just had a small piece of debris in it that washed out when you took the pressure off of the cartridge.
How do I turn the shower on? I just moved into a place that has a Delta series 1400 Monitor shower handle, a smooth faucet, and NO mechanism whatsoever that I can see for switching from bath to shower. Is...
There should be a dirverter on the tub spout. It will be either a knob to pull up or a ring to pull down on and hold untill the water comes out the shower head.
If there is no dirverter go buy a new tub spout with one.. The prior owners may have installed the wrong spout.
Apr 01, 2011 | Delta & Single Handle Shower Faucet
Plumber installed a delta multichoice valve trim 17 two years ago. The water temperature knob is getting harder to turn again. It happened a year ago too and the plumber put in a new cartirdge saying...
not all that familiar with your particular faucet. but in my experience, most plumbers dont put grease on the valves when installing them . the factory just uses enough grease to get the valve in the faucet. if you have extremely hot water and use it . it wont take to long for it to cause this problem.. just an opinion. i cant imagine how the buildings shutoff could have anything to do with your problem.
Dec 10, 2010 | Delta & Single Handle Shower Faucet
Installation Directions were missing from a Delta #132900
first get pair plieyers and a x screw driver once u have ur tools first the shower head look behind the shower head their ull find were u unscrew it get ur plaiyers start unscrewin it after its off before u put the new one put plumbing tap around the threds were u screw the new one 6 in of plumbin tap rapit around the screw threds tighly then screw the new one on now for the temprature adjuster were u turn on an off the water all u need is a x screw driver un screw the screws it shud come off ez then jus do the same thing wit the new one just put the round back peace first get the screw and screw it on then then the water adjuster put it on then screw that part on tightly u shud be ready to go.
Aug 18, 2010 | Delta & Single Handle Shower Faucet
Delta single lever faucet leakingafter bing shut off.
Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
Jun 26, 2010 | Delta & Single Handle Shower Faucet
Just got the tub faucet fixed from leaking now the water will not get hot in the shower how do I fix this problem?
If its a balanced pressure shower then you most likely have installed the cartridge wrong. Remove the trim plates and rotate cartridge 90 degrees clockwise and re-istall trim plates
May 22, 2010 | Delta Faucet Delta RP17453 Pull-Down...
How do you switch out the single lever dial on a delta shower fau
Hidden under the lever is a little hex screw. Use an appropriate hex a.k.a. "Allen" wrench to remove the handle. You might want to shut down the water service first to save your shower until later.
Mar 16, 2010 | Delta & Single Handle Shower Faucet
My delta 132900 gets too hot.
With these Faucets, you can remove the handle and make adjustments to the max Hot water setting (scald guard).
You may also have a faulty or lime-covered cartridge.
SEE THIS SITE for making adjustments/replacing the cartridge.
Thanks for using FixYa - a 4 THUMB rating is appreciated for answering your FREE question.
Aug 23, 2009 | Delta & Single Handle Shower Faucet
Delta shower faucet
Please read here first:
http://www.plbg.com/forum/read.php?1,342033
You may need to call 1-800-345-DELTA (3358) or email them at customerservice@deltafaucet.com.
Mar 15, 2009 | Delta Plumbing
Delta & Single Handle Shower Faucet  Logo
859 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
