Question about Necchi 3102 Mechanical Sewing Machine
I can't get my side cutter to work correctly. It
I can't get my side cutter to work correctly. It will sew, but not cut. What am I doing wrong? It is a Necchi machine.
It might be that u have cut the pin & must change both blades
Posted on Mar 11, 2009
My Husqvarna Opal thread cutter is not cutting the thread from the bobbin.
Huskies are excellent machines. Guessing this is a serger? Doesn't matter. Very likely you could ask Likely, something is a bit out of sync. Or - all sewing machines are 'picky' about being threaded correctly. You might check that.
Jan 23, 2018 | Husqvarna Sewing Machines
Auto thread cutter on my quantum stylist 9960 is not cutting my thread it is going through the correct motion but not actually cutting ? I have cleaned my machine with no changed results, help!?
Please have a trained service technician look at your machine. Cutter blades and mechanisms do require service from time to time, especially with heavy use. If you use your machine frequently, have it cleaned and adjusted based on your use levels.
Embroidery Services
San Diego, CA
Jul 03, 2016 | Sewing Machines
The cutter on my White super lock 1934D has dropped down and won't stay in the correct position to cut. How do I fix this?
The cutter mechanism connects to the machine whet the front is closed. If you look at the machine with the door open. You will see a finger coming out of the inside of the machine. If you turn the hand wheel it should move up and down. On the cutter mechanism there is a fork that fits over the finger. When it is all closed up it sould work together to move the cutter blade up an down. Is the cutter in the up position?
Apr 29, 2015 | Sewing Machines
Cutter on speedylock
Servicing the Timing is NOT a home fix
Mar 08, 2014 | White Sewing Speedylock 1600 Mechanical...
My juki ddl 555-5 with old model auto cutter does not cut thread anymore. how to fix it?
Recording how it fits together before starting is a good idea. Drawing a picture is another method including plenty of detail such as colours. It once made all the difference when reconnecting the hydraulics on a truck. If you feel confident, you could re-try different combinations or have an electrician check it
Feb 28, 2014 | Sewing Machines
Automatic thread cutter not working on Brother super galaxy 2 embroidery machine
you may have to take the machine in to a sewing machine shop to find out why the cutter is not working
Apr 25, 2012 | Sewing Machines
HuskvanaDesigner 1 , automatic thread cutter stopped was working fine .I turned of machine for about 15 minutes. When I turned it on again the cutter didn't work. Can you help? Olga
No real idea what has gone wrong, but first thing I would do would be to clean out the bobbin area thoroughly. There may well be a piece of lint stuck in there that is preventing the mechanism from operating. Is the cutter not working manually i.e. when you touch the cutter button, or not working at thread changes in embroidery? If it in the manual situation you might find that the button is not connecting with the electronics behind that panel correctly and it will need a machine technician to correct it.
Jan 09, 2011 | Husqvarna Viking 1
Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
Necchi 3102 Mechanical Sewing Machine Logo
95 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
