Question about Water Heaters
My gas bill is so high what settings should the temp on the water and ch be set at ?
    Problem Solver:
  • 4 Answers
The temperature setting should not make that big of a difference. Have you checked for gas lines for leaks? You can do this by using a dishwasher soap and water mix, spray it on all the pipes and if there is a leak it will blow bubbles. Do you have a drippy faucet on the hot side? Do you have gas heating for your house?
If it is an older heater, you may want to flush out the sediment from the heater by attaching a hose to the valve at the bottom, open the valve and let the water run down a drain for a few minutes.
That said, set it at a temperature below scalding.
Posted on Mar 03, 2009
Rheem hot water heater says set temp? no hot water
If it is a gas water heater you must set the temp on the gas valve. Press the two outside buttons until they flash. Now you can use the arrow button to set temp.
Jun 25, 2016 | Rheem Water Heaters
Richmond water heater, water is not hot , pilot is on
Sometimes when master burner is clogged with shards it will turn itself off. Try to clean master with a high-pressure air.
Dec 09, 2014 | Water Water Heaters
Keystone manuals rv
You would need to buy a propane hot water heater. Unfortunately you can not convert an electric hot water hearter to propane.
I didn't want to use either an electric or gas hot water heater so I invested in a solar hot water heater for my home. Best thing that I ever did as far as saving money. Once it is paid off then the benefits are lower utility bills.
Good luck,
Marty
Jul 15, 2014 | Water Heaters
I turned up the water temp on my gas water tank, and water leaked from the side pipe..do I need to repalce the pressure release valve or is this normal?
Any time your pressure release valve goes off you should replace it. the t&p valve responds to the temperature and pressure its possible that the setting you chose was to hot, or its possible that the relief valve was just worn out. I would replace that and keep your temp setting between B and C. another possibility is thermal expansion, check and make sure your expansion tank is good and if you don't have one I highly recommend it.
Jun 28, 2014 | Bradford White M45036fbn 50 Gallon Natural...
Greenstar 30cdi no hot water
It is the shower head or plumbing that has a built in mixer or reducer.
Dec 09, 2013 | Stiebel Eltron CK20E Electric Tankless...
Greenstar 30cdi hot water issue
The problem is not the water heater. The shower has a mixer or a limiter built into the plumbing so that the water wont get hot. It is a safety feature to prevent burns and protect children from scalding.
Dec 09, 2013 | Water Heaters
Flashing ch on greenstar 42cdi boiler
ch calling for heat check ignitor or heating element
Oct 18, 2017 | Water Heaters
Once hot water is open the gas is burning and water is not heated
Sounds like the flow is too high and or the temp set too low.
Apr 01, 2009 | Bosch Water Heaters
Heating element cycling on and off fairly often
Yes, unfortunelty elextric water heaters do cycle a lot. They are a little bit different from gas water heaters, in the fact that they run differently and seem to run out of hot water faster, then gas water heaters. Just make sure, that the thermostat is set at 120 F. The thermostat will be behind a panel, and under the electrical wire connections. You will have to use a flathead screw driver, to change the temp. settings, if they need changing. Also, make sure that once a year, that you flip the Pressure relief valve to equalize the pressure and to drain at least 2 gallons of water out of the tank.
Jan 20, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
A.O. Smith Water Heater Problems
someone has messed with the differential setting - so the water heats to correct temp but cools too low before coming on. get book -easy fix
Oct 26, 2008 | Water Heaters
Water Heaters Logo
85 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
