Question about Coleman Powermate Powermate 5000W Generator
Wolf generator fitting a new switch 110 v to 240 v
The switch broke on the 110 to 240v it has 9 screw in prongs on the back but we dont no where the wires came from so we need a wiring diagram and wolf say they dont have one can any one help .
Thanks Frank
  • 98 Answers
Frank...send me a photo of this part and other photos wll be helpfull....i'll be glad to help u /...
sal_kh_sab@yahoo.com
Posted on Oct 16, 2009
I have a 4 prong tanning bed 220v and my appliance outlet at home only accepts the 3 prong plus such as the ones you see on a dryer. How can i get this converted to a 3 prong so that i can plug it in? Or...
It is because you tanning bed requires L1 and L2 (240V) and a seperate neutral, and a ground. You need an electrician to install a proper outlet. A dryer (years ago) was installed without a neautral. However per NEC electrical code even new dryers have to have 4 wires. Do not attempt to use on 3 wires !
Oct 02, 2013 | Coleman Powermate Premium Plus 6250W...
Wolf 5000kva generator
Locate where the choke lever is for your generator (under the petrol tank), you ought to notice a star headed shaped screw connected to the governor shaft (if you bend and look closely further beyond the choke lever; still under the petrol tank) which is linked to the carburettor housing/assembly. You need to increase/turn clockwise (using a star screwdriver) on this screw.
Your generator engine sound will change/high a bit because the engine speed will increase.
Reconnect your 1800w chop saw (load) and see if your generator can "effortlessly" accommodate it without shutting down otherwise, increae the turns on this adjustment screw attached to the governor shaft till your generator operates/stabilizes with the load (1800w) connected
Oct 05, 2017 | Wolf Manufacturing Electrical Supplies
Want to add 240volt outlet to generator
You CANNOT do this, USA 240V is derived from a poly phase scenario, IE 120V line to neautral and 240V line to line, UK 240V is derived from 1 line to neutral it will not work unless you power a transformer
May 16, 2012 | Coleman Powermate Powermate 5000W...
We have s6000 generator and a 38 foot camper that runs on 30amp. Do we need to buy and adaptor and can we use the 30 amp plug on the generator. And do we use the 4 prong or three prong
You will probably have to buy an adaptor. Read the owners manual for the generator, the 4 prong should only be for 240V. The 3 prong should be 120V. But READ the owners manual. If it is this way you should be able to get an adaptor at your local hardware/electrical supplier or any RV store.
Jan 31, 2011 | Electronics - Others
Have a wolf range and the spark generator which lights the burners will not stop clicking even when i turn the stove off. if I turn on the middle back burner it will stop clicking. how do i stop this?
Remove the knobs and skirts and a few screws. Remove the panel and locate the spark switch that is bad by removing one wire at a time till the ticking stops. dfc80e7.jpg
Jul 16, 2010 | Wolf Range CHR-2-1829-FT45 Gas Kitchen...
Operation of a Devilbiss GT5000 generator
not to familiar with the generators however , I do know that the old style receptacle for 240 volts was three prong. Then OSHA got a hold of it and added a second ground to make it 4 prong, Thats why some houses use a 3 prong dryer cord and some use a 4 prong. hope this helps. and if it has 2 240v outputs BONUS they dont make em like they used to.
Aug 13, 2009 | Electrical Supplies
JUST CHANGED MY GE DRYER TO A 4 PRONG PLUG, NOW NO HEAT
Sounds like your heating element is burned out (acually burned threw) when you moved it if the element was weak it may have broke in two along the coil wires.
Happens alot.
Feb 17, 2009 | GE Dryers
TWIST PLUG
go to an electric supply store and let them know it is a 20 amp plug. The big box stores only have a few selections of plugs
I had the same generator and had to modify the plug to make it fit correctly
Jan 08, 2009 | Coleman Powermate Powermate 5000W...
I have a 5000w colman generator w/ 2 standerd 120v outlets, 1twist 120/240v outlet. the grounding prong goes out all i can find are cords that go in ???
Go to an Electric supply store and tell them it is a 20 amp plug. They should be able to get the correct plug.
I had this generator and had to adjust the prong to make it work.
Coleman Powermate Powermate 5000W Generator Logo
534 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
