Question about Estate TAWS800JQ Top Load Washer
Trying to replace switch that operates spin cycle
I need to replace the switch that turn agitator on and off when lid is lifted,but i cant figure out how to open the unit up....It is a whirlpool,lsr8233jq,top loader,please help!!!!!!
  • Estate Master
  • 8,205 Answers
The case comes off READ THIS
Posted on Mar 03, 2009
I have a Kenmore washer model 110.26832690 that will not spin. It will fill up, agitate, but on spin cycle it will only drain. Does this sound like a bad lid switch or a bad drive adapter? From what I've...
if it agitates correctly,then its likely your lid safety switch, agitate and spin cycles are reversed by the motor during the cycles of agitate and spin,some units are wired to not operate on either agitate or spin,but some will operate on agitate with the lid open,but not on spin,open control panel and bypass the lid switch and this will tell you before you tear out the direct drive pump,motor and get to the d.d. coupler at the transmission
Mar 20, 2011 | Kenmore Washing Machines
Maytag Performa washer drum turns with agitator. Also the brake doesn't stop the drum at end of cycle or when cover lifted.
The first thing to check is the clutch. It's supposed to lock the inner tub and drive the transmission (agitator) when the motor turns in one direction, and spin the tub when the motor turns in the other direction. It's also possible the agitator drive shaft coming out of the transmission and the concentric tub drive shaft are frozen together (worst case) - this is usually caused by a bad bearing seal allowing water to leak into the shaft.
Lifting the lid during the spin cycle should disconnect power to the motor - maybe what you see is the tub continuing to spin because the transmission is acting as a flywheel. Either that, or the lid switch actuator is not working properly.
Nov 27, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Roper washing machine agitates but will not drain or spin
its your lid switch. it cant spin til that switch is closed,and they break all the time.its thru that hole where the lid seats on the top of the washer.also some times the switch actuator on the lid breaks,but not as offten.inspect that area and you will see issue.you can cut and connect the wires underthere in a pinch[there are three wires to the lid switch.dont connect the green ground its the other two]but you must be careful if you have children they will be curious and lift the lid and it wont stop spinning,so if they reach in with there arm,their has been cases of arms being torn of from spinning tub.how this helps God bless ,tom
Jan 26, 2009 | Washing Machines
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Estate TAWS800JQ Top Load Washer Logo
110 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
Anastasio Benjou
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
