Question about Frigidaire FEF352 Electric Kitchen Range
WhenI try to bake or broil--get error msg. F13
Frigidaire Professional Series Electirc Range
  • Frigidaire Master
  • 3,361 Answers
Unplug the oven.
Wait 30 seconds and plug it back in.
If the code reappears you must replace the EOC.9electronic clock).
Posted on Mar 04, 2009
Frigidaire fault code f13 kitchen range what does that mean ?
Thank you for your inquiry, raymond bouley!
I understand that your Frigidaire range is displaying an error code of "F13". An "F13" error code typically stands for a bad EEPROM (Erasable Programmable Memory) identification or check sum error. The best way to clear this code is to disconnect power from your range for roughly ten minutes. If you continue to experience an issue it could be a possible that you have a faulty board or wiring harness. I would then recommend having a professional out to perform a diagnosis on your range. Hope this helps. -Matt
Jan 13, 2015 | Frigidaire Kitchen Ranges
I have a frigidair Gallery Series Range. All of a sudden I get a F13 error code when I try to Bake or Broil
hmmm...can you go to the main circuit breaker panel, turn off the power to that unit, and reset it, by turning the breaker back on. You'll need to reset the clock after this, yet you may find you'll be in good stead.
Apr 28, 2008 | Kitchen Ranges
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
40 duel fuel frigidaire/electrolux convection oven doesnot work self cleaner doesnot work .
Hello Walter Buford - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the unit. Select the self-clean option or bake/broil option. If it does not turn on, then the temperature may have tripped the internal sensor of the unit and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Possibly the unit may have a communication problem with the EOC (Electronic Oven Control) or faulty element(s). Personally, I would recommend contacting a professional for further evaluation.
Apr 14, 2013 | Electrolux Frigidaire Professional Series...
Why my oven shows f 13
your eoc is bad, electronic oven control (clock)
Apr 11, 2013 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire es300 gas range kepps flashing f10 and f13.how to resetand get the clock working
Hello Carol Martin - Typically, error codes F10 and F13 could indicate a variety of issues. The range could possibly have a shorted keypad, runaway temperature (higher than normal temperature), faulty EOC (electronic oven control) or, display wire harness missing/not connected. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Mar 06, 2013 | Frigidaire Gallery GLEFZ384GC Kitchen...
Is there an oven reset button on a frigidaire range fefl79jba?
Hello G Rego - The range may be reset by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, turn on the range and select bake or broil option. Should all troubleshooting measures fail, I would strongly recommend consulting a professional to move forward accurately. The range could possibly be experiencing a wiring failure, EOC (electronic oven control), sensor probe and/or faulty element(s). You can often local service providers by visiting the manufacturer website.
Feb 28, 2013 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Getting F13 err code when trying to bake or broil. Frigidare model PLES399EC
Hi william_j522,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
try disconnecting power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
Regards
R.K.
Oct 22, 2009 | Frigidaire PLES399EC Electric Kitchen...
Receiving Error F13
Turn the breaker to the stove off for one minute, reset time and everything should work just fine. It worked for me.
Ken
Jan 08, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Frigidaire FEF352 Electric Kitchen Range Logo
507 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
