Cant received faxes unless i turn aauto answer button off and and on again
SOLUTION:
Make sure the printer is on and is connected to a working phone line.
Make sure that Auto Answer is on.
To check if Auto Answer is on:
From the printer control panel press the wrench sign.
Press the arrow buttons until Fax Setup appears, .
Press the arrow buttons until Ringing and Answering appears, and then press
OK to save the setting.
Press OK again.
Check to see if Auto Answer is set to On.
If Auto Answer is not set to on, press the arrow buttons until On appears, and then
press to save the setting.
Set the number of times the telephone rings before the printer automatically
receives faxes:
Press the arrow buttons until Pick-up On appears, and then press OK .
Press the arrow buttons until the setting that you want appears, and then press to
save the setting.
When the number of rings you set is detected, the printer automatically receives
the incoming fax.
This should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
