Question about Epson Stylus CX9400 Photo Printer
Our Epson Sylus CX9400Fax Series is not receiving or sending faxes. We have already done the phone call to India thing for 90 minutes. All settings were changed and tested. They are now back to factory default. Any attempt to send or receive results in "A communication error has occurred during the fax transaction. Error 0400. What now?
  • Pat Wick Mar 03, 2009
    Been there-done it all. Everything except the DSL because we are not on DSL. Up and down speeds are excellent on the internet. Phones at both ends will ring properly. Fax window says it is sending/receiving and then Poof! Error 0400!! All done! Finished. Bye Bye!
  • 6,784 Answers
Ok, here's a check list for you.
SENDING
Check the following:
  • Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
  • Make sure that your recipient's fax machine is turned on and working.
  • If you connected the Epson Stylus CX to a DSL phone line, you must install a DSL filter to the line or you won't be able to fax. Contact your DSL provider for the necessary filter.
  • If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
    Follow these steps to turn off the ECM setting:
    1. Press Setup.
    2. Select Fax Settings, then press OK. You see this screen:
    3. Our Epson Sylus CX9400Fax Series is not receiving - cp_display_141_er.gif
    4. Select Communication, then press OK.
    5. Press cp_button_44_er.gif Our Epson Sylus CX9400Fax Series is not receiving - cp_button_42_er.gifb>. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
RECEIVING
Try the following if you can't receive a fax:
  • To receive faxes automatically, make sure the Auto Answer light is tuOur Epson Sylus CX9400Fax Series is not receiving - cp_display_142_er.gifn, press the Auto Answer/Space button.
  • Make sure paper is loaded.
    1. Press
    4. Communication then press OK.
    5. Press cp_button_44_er.gif and select ECM. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
Posted on Mar 03, 2009
  • Michael Masters
    Michael Masters Mar 03, 2009
    i see, i would try a hard reset. unplug the unit for five minutes. if that doesn't work, you may need a software/firmware update from the manufactures website.
What is error message 0407?
EPSON Stylus error message 0407
Aug 11, 2014 | EPSON Stylus CX9400Fax Series
For sending multi-page fax, I get the feed error after scanning the first page in Epson cx9400fax. please help.
That could be many things. Check your feed rails are tight against the paper. Also make sure you are not
overloading the feed. For other suggestions go here -
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1635278753.1300892813@@@@&BV_EngineID=ccgcadfddljflficfngcfkmdhjidfmh.0&cookies=no&infoType=FAQ&oid=90753&prodoid=63070382&foid=102327&cat=30961&subcat=30959
Mar 23, 2011 | Epson Stylus CX9400 Photo Printer
Fax Problems
check and verify that the land line is correctly plugged into the right connector at the back of the fax.. secondly check that you actually have a dial tone.. this is not a fax problem.. its a connectivity problem.. Smiles
Mar 31, 2010 | Epson Stylus CX9400Fax InkJet Photo...
I had a wireless router installed and can no longer fax using CX9400FAX series. Receive communication error ''no dial tone''. There is a phone line from the phone to printer and from printer to wall jack....
I too was having the same problem. We too have a wireless router hooked up. However, that had nothing to do with the problem. Our problem was that the top phone line port on the fax machine should run to the phone jax in the wall. The bottom phone line port on the machine should run to the phone. We had them switched around.
I hope this helps.
Dec 22, 2009 | Epson Stylus CX9400Fax InkJet Photo...
How do I enlarge the print on an Epson Stylus CX9400 fax series?
the printing wizard it has the size choice ...but the actual size its established by the limitations of the printer ..anyway all documents may be re-sized in the computer and than printed...even in pieces and reattached after if the printer supports only A4 paper maximum
Sep 04, 2009 | Epson Stylus CX9400Fax InkJet Photo...
How do I receive faxes with an Epson Stylus 300f?
your computer has to be set to answer the phone so it receives the data and sends it to your printer. unless the data is demodulated via the modem or other demodulating softwarew .. it cannot be printed and or viewed. check your settings in the "printers and faxes area of the control panel to verify proper settings or make any necessary changes.
May 20, 2009 | Epson Stylus C86 InkJet Printer
Can't send or receive
fax machines are analog devices and will not work reliably on a digital phone line.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Cx9400fax
Epson Quick Guide is incorrect.
Not sure of your exact situation but .........
Your answering machine MUST be connected directly to the output of your CX9400 and you can't use an answering machine with multiple "mailboxes". Set your answering machine to 4 and your CX9400 to 5/6 rings. Epson "Technical Support" has no clue of this problem .... yet.
The machine routes the call to your answering machine, it it's an incoming FAX and the answering machine starts the CX9400 will recognize the incoming transmit signal, turn on the FAX function, and disconnect your answering machine.
You may need to adjust the CX9400 rings setting based upon the duration of your answering machines announce message (longer message = greater number)
Jan 28, 2008 | Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400 Photo Printer Logo
1,605 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
