Question about PNY 8GB USB 2.0 Flash Drive - Blue/Black
Clear memory stick
PNY Attache 8G, how do I clear the memory and start again?
  • qbanruben76 Apr 22, 2009
    my 8gig drive only shows 78mb of drive space.i tried formatting but only get 78 mb
    Guru:
  • 509 Answers
The easiest way is just select all and delete
Posted on Jan 03, 2010
Windows XP home edition not regonising PNY pendrive micro attache 2G
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
Dec 27, 2010 | PNY 4GB Micro Attache USB 2.0 Flash Drive
My hp mini 8g is all used up and I do not know why? I only use this to serve the net, no downloading etc... I tried to have the drive defragged but even that does not work? Any solutions?
If you have an HP mini like the 1010nr, you may have only an 8GB solid-state "drive" the solution is to: 1) plug in a usb drive to a side port for extra space; or, 2) BETTER - pull off the cover on the right side to access the hidden USB port and install a permanent large-capacity usb memory module, then replace the cover. This requires a small usb stick with little or no case (like this: http://www.ebay.com/itm/PNY-Attache-Paris-16GB-16G-USB-Flash-Drive-Stick-Purple-/250804063654?pt=US_USB_Flash_Drives&hash=item3a65164da6) -REMOVE THE OUTER CASE FIRST.
Aug 19, 2010 | HP Mini 1010NR Notebook
Need driver for pny mini attache 2.0
Here are a few possible sources for your driver software :
http://en.kioskea.net/guide/905619-pny-pny-mini-attache-4gb-usb-2-0
www.paretologic.com/lp/drivercure
http://www.helpdrivers.com/ingles/listado/panel.asp?marca=PNY&perif=otros
http://driverscollection.com/?V=PNY&S=48
try these sites they should provide you with success
Jan 04, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Pny attache optima pro 8g usb drive disk space problem
Yes, and Perfectly too.
What you should do is,
depending on your operating system,
Right-Click on 'My Computer Icon', then select 'Manage'.
When you get to Computer Management page,
Click on Disk Management on left hand side,
This will display ALL the disks installed on your system, either partitioned or not partitioned, formatted or not formatted.
Then go to the ones that are hidden, not created, or not displayed, right-click on it, then you'll see different actions that you can perform.
Also, in some instances, what you just need to do when you get to this page is to assign a new, distinct, drive letter apart from the ones already in use on the system.
This will automatically bring out the hidden drives.
Hope I have helped you out.
Goodluck
Oct 29, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
4GB Attache flash drive says it's locked.
Plug in the stick. wait for it to come up on the desktop then click on it once. (do not open it).
From the file menu select "Get Info"
In the panel that opens up you will see a row of coloured squares. Underneath is a checkbox marked "Locked"
Is it empty or ticked?
If it's ticked, untick and see what happens in disk utility. If it's not ticked that then would appear to be a problem with the stick.
For what it's worth, I did a google on this stick and found that there are numerous posts about it becoming read only on Vista, so it may well be a problem with the manufacturer.
Sep 07, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Can't clear memory stick
I am Rob and a expert on camera repair. Please use a universal cardreader they are very cheep and helpfull to clear or format the memory from every brand.
Mar 22, 2009 | Cameras
Computer reboots when i connect my Thumbdrive
More then likely you have a defective thumbdrive,buy a new one and see if you still have the problem, you can all ways take it back if you still have the problem, Remember new ones can also be defective.
Mar 03, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Pny memory stick
once it is erased of your pen drive it is erased for ever
(you dont want to format it it will erase your date)
hope this helps :-)
Aug 31, 2008 | Electronics - Others
PNY 8GB USB 2.0 Flash Drive - Blue/Black Logo
398 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
