Question about NetGear WGR614 Wireless Router
Im using a difrent pc cause my other one brokedown i have a netgear router but not the cd i have missed placed it , how can i get this program and drivers from the internet,
  • 854 Answers
Hello markymaninco,
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 12, 2009
Netgear RT311 i have no cd to help set it up. what can i do
use your web page and with router plugged into the computer type 192.168.1.1.This should get you to a log on page the username is admin and the password is password.
Jan 16, 2012 | NetGear RT311 Router
I HAVE A RANGEMAX WIRELESS ROUTER BUT I DONT REMEMBER THE ASSWORD I UT ON THE ROUTER AND I DONT HAVE THE CD SO I COULD INSTALL IT AGAIN IS THERE A DIFRENT WAY I COULD INSTALL IT?
Yes. Are you referring to the WEP password which you use to connect to the wireless? If you are referring to WEP you can reset it by logging into the router through the admin panel with the admin login details(assuming you have them) and then chnage or reset the WEP password. If you are dont have access to the ADMIN console and also the WEP then you have to reset the router to its default settings. But before doing that please make sure you know all the settings with which the router needs to be configured with.
Apr 12, 2010 | NetGear RangeMax WPN824 Wireless Router
Linking the netgear wndr 3300 to xbox 360 and laptop
configure ur netgear accordinglt... usually netgears are 192.168.1.1 or 192.168.0.1 with username admin and password as password.
make sure u reset ur router first and then reconfigure it with this
Jan 10, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Where can i find a netgear wireless router program to download?
The logical place to start is www.netgear.com.
But what do you mean "wireless router program"?
A Netgear router is configured using your web browser (Firefox, Opera, Explorer whatever.) as are most routers.
You access it by logging in at http://192.168.0.1 (or 1.1 on some models).
The login name is admin and the password is password.
Then press the set up wizard and that is normally it.
To set up wireless security follow the prompts down the right hand side of the screen.
Sep 21, 2009 | NetGear Computers & Internet
Netgear DG834G V4 Website connection problems
Please try to use a difrent DNS service.
For example open DNS:
Primary: 208.67.222.222
Secundary: 208.67.220.220
Jan 14, 2009 | NetGear DG834G Router
Modum
You do not have to use the cd.
Go to the control panel and un-install the program that the cd installed.
then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 30, 2008 | NetGear WGR614 Wireless Router
How do I set up the router
Your answer is right here http://kb.netgear.com/app/products/model/a_id/2589 Manual, Documentation, everything that you need is on that page. Hope that helps.
Nov 17, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
43 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
