Question about Toshiba 23HLV85 Television
Base #72796233 for toshiba 23hlv85
I have a Toshiba 23HLV85 set mounted on the wall, it is in great shape, however during my move the base was lost and I according to Toshiba (and pretty much everyone else on the Internet) is no longer available. I do not necessarily need a new one, but I do need the base. Toshiba cant even supply me with an alternative, please help me Thank you!
wendy
  • Anonymous Mar 06, 2009
    Toshiba part posted greatly appreciated, however-part is listed as NA (not available) welcome any other suggestions. Thanks,
    Wendy
  • 362 Answers
Hi wsolem3
The base can be purchased here http://www.encompassparts.com/products/?72796233
Let me know if I can assist further.
Lone99star
Posted on Mar 03, 2009
Can my Toshiba 42WL58A be hung on a wall? Where can I find a manual for it? I've lost me manual and can't find any information on it.
Unfortunately the TV is not designed to mount on wall. Hence there is no wall mount bracket available from Toshiba to install it.. However, if you have a base in your wall you can use the supplied clip to hold it on the wall from leaning forward..
If you lost the manual, you can download the manual from the following link:
http://www.mytoshiba.com.au/support/televisions/lcd-tv/wl58a/42wl58a/download
Jan 20, 2011 | Televison & Video
Red power light on when plugged in but no picture. Power button and remote do nothing. No smell like a bad power supply,any help....Thanks
Please read my guides first to get some understanding so you can narrow down the problem before ordering any parts.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 12, 2011 | Toshiba 23HLV85 Television
I have the toshiba 23hlv85 and it will not power up, red light on when plugged in, maybe the power source???
Hello Corey hi, Its not the power source but the power supply circuit board on your TV. this is where the red light is connected. this simply means that there is an overload/short circuit somewhere inside your TV. this overload prevents the power supply board to turn on for protection. To find the overload in your TV, needs the services of a technician. Usually they swap boards and isolate where the problem is. I suggest you inquire about your problem to your dealer. see if they have after-market service.
Oct 20, 2010 | Toshiba 23HLV85 Television
After working perfectly for 4 years suddenly the screen goes to blue only when I turn it on. The DVD portion works but not the TV screen.
This is due to the fact that the front end of the RF section is faulty and so there is no signal available to the video amp to be processed.
The fault can be any where from the input tuner, the VI F/SIF sections or the conversions( A/D).
You might ahve to start with a signal test to arrive easily at issue, possible that it can be the tuner itself as it most prone to failure.
Finally check the mode section secction of the AV/tuner which can be a suspected area due to a gate failure.
Sep 30, 2010 | Toshiba 23HLV85 Television
Main circuit board part # 72796173..cost of replacement?
$185 here http://tv-part.com/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&cid=0&q=72796173&x=0&y=0
and $263.95 here http://www.partstore.com/SearchResults.aspx?q=72796173&x=12&y=7
Jul 01, 2010 | Toshiba 23HLV85 Television
Toshiba 23HLV85 LCD TV/DVD inverted image
Yes,Ur main Tuner board have problems,the ICS on the board is not coverting.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 14, 2010 | Toshiba 23HLV85 Television
TV DOES NOT COME ON AT ALL
Bad power supply. Symptoms: No display at all, no power indicator light, no sound from speakers, momentary popping or clicking noise, "burnt electronics" smell. Typically caused by failed capacitors. Can be usually be repalced and continue to have working display for a long time. Repair: Replace power supply. Super cheap when it's just a couple of bad capacitor to medium expense when repalcing whole power supply unit.
-=/ Daft Tech /=-
Oct 22, 2009 | Toshiba 23HLV85 Television
Front red light comes on when pluged in, but no power the the tv
be sure all units are auto volt. if you plug units 110V to 220V it might be damage or fuse will blown up.
Jun 28, 2009 | Toshiba 23HLV85 Television
No video
First before you spend crazy money on a new monitor try updating your video card driver.
Jun 20, 2009 | Toshiba 23HLV85 Television
Phillips 42 inch tv
Vendor nap.jpg Part Number 310430814621 Description Stand Base
Tritronics, Inc.
(800) 638-3328
call these guys and they should be able to locate it for you or at least tell you where to get one.
Mar 18, 2009 | Philips Televison & Video
Toshiba 23HLV85 Television Logo
225 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
