Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
My tv is showing a double picture in red - Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
    Genius:
  • 1,550 Answers
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Posted on Mar 03, 2009
  • 927 Answers
SOURCE: big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Posted on Apr 03, 2008
romsky79
  • 822 Answers
SOURCE: when I turn on my tv it has green,red,blue lines going across it
its in your LCD connector re-connect it properly.
Posted on May 28, 2009
stonephoenix
  • 563 Answers
SOURCE: imge is showing double and red
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. Normally it will cost at least $75 to have the set looked at by a repair shop (diagnostics). If the part needed to complete the repair is available, that money will apply towards the labor costs.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
  • 8457 Answers
SOURCE: My RCA, HDTV projection screen tv is showing double red and green
Ur tv have a convergence problems,it dead.The 2 STK convergence ICS are defective,must be change and it supporting resistors.The shop will fix it for u for $300-350 for parts and labors.
Posted on May 09, 2010
Ecollier2012
  • 3459 Answers
SOURCE: my tv is showing a double picture in red
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 03, 2010
Double picture...not focusing right
maybe parts inside is worn out. causing the blurrines. just consult to your service center.
Jun 19, 2010 | Hitachi 43UWX10B 43" Rear Projection...
May 09, 2010 | RCA D52W19 52" Rear Projection Television
TV has red lines and showing double the picture. One Sears tech suggested may have to replace bulb for $500???
yes thats a good price to replace a bad red picture tube and at the same time the convergence ic , this is for the doble picture and lines
Apr 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Our Sony Projection TV has the red color distorted
Double picture symptom shows tv got problem with convergence out section and most probably convergence out chips would be replace to fix this issue.
Though its job of qualified tv tech to replace convergence out chips yet I can provide you helpful info if you are handy with electronics stuff repair and can replace parts in circuit board as soldering work is needed with proper tools to repair tv.
Thanks.
Mar 14, 2010 | Sony KP-51WS510 51" Rear Projection...
Double image the second showing in red PT 53TW53G
replace the convergence ic's or look for loose connections that should do the job
Dec 16, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Big screen showing double and red ghost color
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
163 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
