Question about Westinghouse 25.5" Widescreen Flat Panel LCD HD Monitor
Black screen My mother puchased a Westinghouse Flat screen monitor Model L2046NV only 4 months ago, the screen went black and the green light is still on? She no longer has the Walmart receipt is there anything she can do without the receipt?
    Genius:
  • 2,120 Answers
Hopefully, she registered it with Westinghouse. Call their tech support.
maybe a transaction printout from her bank account will suffice.
Posted on Mar 05, 2009
Monitor will not turn on? westinghouse model L2046NV black screen will not turn on what should I do?
Do you see an orange light on the monitor anywhere? Usually the light turns green when the monitor comes on, but its orange when in "standby" mode. If your monitor is plugged in and you get an orange light, that usually means that your video card has gone out on your computer. When your video card goes out, the monitor doesn't receive a signal from your computer, so it doesn't know it is suppose to turn on. So if this is the case, you need to replace the video card on your computer
If your monitor doesn't turn on whatsoever, and everything is plugged in correctly, then you need to get a new monitor or send this one back to the manufacturer for a defective replacement.
Hope this helps! :)
May 03, 2010 | Westinghouse L2046NV Monitor
L2046NV Monitor Does Not Display, but Another Monitor Will.
The problem is with the Westinghouse monitor. The video card inside the monitor is most likely faulty. There are 2 cards inside, 1 is the power supply and the other video. The power cards are typically OK if you are getting a green power indicator. The video card is most likely the culprit and will need to be replaced. If you open the case, BEWARE the capacitors, make sure you drain them before poking around.
Apr 13, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
Westinghouse 22 lcd monitor. faint click and went
More likely the filter caps failed and may have taken out the inverter fuse and the MOSFET in the inverter circuits also. yoo need to open it up and inspect the inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 09, 2010 | Westinghouse L2046NV Monitor
The monitor screen went black and I noticed the power light goes from green to orange as if it is going to sleep? how do I repair this.
Hi my name is Roety,
I can help you with your issue ,
All you can check is for swollen capacitors visually
after that voltage tests would localize the bad part
Power supply
Main board
panel with tcon and invertors
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Jan 29, 2010 | Westinghouse L2046NV Monitor
How do I reset my Westinghouse L2046NV monitor -- this monitor will turn on and light up and the picture will come on but then go off after 1 or 2 seconds -- any ideas ?
Hello, reseting your monitor will not solve the problem, what you need to do is replace the inverter board, if you would like to know price and availability for this model please send a request to parts@wde.com, they will let you know if they have the board, how mutch it is, and they will also troubleshoot with you over the phone at no charge to make sure that is what you need.
Dec 15, 2009 | Westinghouse L2046NV Monitor
Black screen after a brief windows loggin screen
Hello
It's either the backlight, the inverter or the power supply. My shop would charge $50.00 + parts + shipping. I've repaired alot of Westinghouse monitors and I haven't junked one yet.
Jul 28, 2009 | Westinghouse L2046NV Monitor
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
No Image on Monitor Westinghouse L2046NV
well i just had this problem this morning i woke up turned on the monitor and it came on but went out. but i soon found out it was not the display that is not coming on its the black light. if you look closely you can see the display but there is no light to light it up so you can see. it doesent seem to be anything wrong with the circuit board just the black light i am going to be taking the monitor apart to see if there is anything me or any of you can do for the monitor to fix it.
Jul 26, 2008 | Westinghouse L2046NV Monitor
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Westinghouse 25.5" Widescreen Flat Panel LCD HD Monitor Logo
327 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Paul Bade
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
