Question about Myron & Davis AK1154W 15.4 in. Car Monitor
Need wiring diagram for din cable
I need the wiring schematic for the wires inside the din cable for this monitor. can anyone help? myron and davis ak-1154w
No power to my Myron and Davis did player in my 1999 Yukon
That is not factory installed unit so first step if you k own where the wire connect to the trucks wiring (most installers use either the wiring behind the radio or at the fuse box) there may be 2 power wires usually they both have fuses. Check those first if you can find them easily. If bot you will need to drop the monitor (I assume it is ceiling mounted). Check for power and ground on the wires at the unit. Usually there is a red and a yello. Red has 12v with ignition on, yellow has 12 v always and black is ground. If the power at the monitors good then the unit is bad. If this is a split system (seperate DVD and sepe8monitor ( check same at both units. If you are not comfortable doing this any car audio shop can check it for you.
Jul 08, 2016 | Car Audio & Video
Tip
How to connect your dvd to tv
This is for those who are struggling to connect rca cables to tv. Cables are normally color coded, yellow is for video (out from dvd snd in to the tv). Red and black sometimes white is for audio (left and right). Same thing here out from dvd in to the tv.
on Jan 01, 2014 | Myron & Davis ADVD370 DVD VCDSVCDCD-R...
Hi .."my Myron and Davis
The optical lens of your dvd is almost dirty try to use a cd cleaner. hope that this may help.
Jul 10, 2011 | Myron & Davis Televison & Video
Need a wiring diagram for myron&davis TFT-LCD color monitor 7 in. model number AXV-070-FB-PA
why do you need a wiring diagram for . heres the thing if you need to have a diagram take it to a professional b4 you fry something .
on any monitor there is on power and ground and audio output and and video inputs
unless you have a dvd built in you will not have a constant power wire
red igintion 12 volts
black ground
yellow rca cable is video in
should be second yellow for video 2 input
some monitors have red and black rca audio outputs to the radio
caraudioquestion@gmail.com
for more info
Oct 14, 2010 | Car Audio & Video
I see the picture but i get no sound, what radio station do i put it in in my suv
Do you have a manual with your Car Monitor? If you do there will be the frequency that it uses to transmit to your car stereo, probably listed under the audio or setup section.
If you don't I suggest that you call Myron & Davis on 909-796-3199 and tell them your model and your problem, they will be able to tell you what frequency you need to set your radio to. You can also email them techsupport@myronanddavis.com. Their website is here if you have any other issues.
Jun 18, 2010 | Myron & Davis AK1154W 15.4 in. Car Monitor
I have a Myron & Davis AD256T dvd player and the problem I have is, Cant see video games from the rca the video game get froze on the tv screen from the begining and dont let me play
It could be a game console connection problem, make sure that your Yello RCA output is going in your Video input on the monitor or monitor receiver. You might have a power or voltage problem, if the wrong current or voltage is incorrect then errors and freeze ups can happen, the player wont support the wrong voltage going in. Check your power connections, Video out/input connections and check your voltages.
Good luck.
Make sure to vote and rate me if I helped you. thanks
Jun 13, 2010 | Myron & Davis AD-256T Car Video Player
Dual DVD Headrest System
you could try an fm modulator which allows you to tune your radio to the set frequency and then gives you sound through your speakers
May 23, 2008 | Myron & Davis Myron Davis 6.0 " TFT/LCD...
Myron & Davis AK1154W 15.4 in. Car Monitor Logo
145 people viewed this question
Top Myron & Davis Car Audio & Video Experts
noagge
xxxxxx xxx
Tom Chichester
Are you a Myron & Davis Car Audio and Video Expert? Answer questions, earn points and help others
