Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
The motor is working but the chuck head is not turning properly - it turns and then when you put pressure on it it stops. I have 3 makita drills and this is happening with all of them
  • 1 more comment
  • robertj_coon Mar 04, 2009
    Makita 8444D
  • david549 Apr 20, 2009
    I have a 8444 combi and when pressure is put on to drill it seems to disengage, the motor is still working but the chuck can be stopped with light hand pressure. All switches are engaged correctly.
    Only had light use and quite frankly this is very poor reliability.
    This model wouldn't last 1 day in the pro field.
    Regards, David
  • David Ford
    David Ford May 11, 2010
    what is the model number
    Problem Solver:
  • 12 Answers
First, check the lever on the top of the drill (high/ low lever speed) and make sure it is engaged in one of the positions. If it is in the middle it will cause your drill to stop. Otherwise, the gear box is gone and will need to replaced. The part # you need is #125-429-0 and it runs about $59.20.
Good luck
Posted on Mar 05, 2009
Makita bhp453 chuck screw wont loosen
The chuck screw on drills is put in with lok-tite and is reverse threaded. You need to get the screwdriver on it firmly and turn it clockwise, as you are, with strong, constant pressure until it breaks free. Don't let the screwdriver slide out of the screw slot, if you round off the screw head you'll have to cut the chuck off. If it still won't break free, try putting the drill in a vice or use a screwdriver with a hex nut molded into the driver shaft so you can use a wrench for some more torque.
Mar 11, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
I have just purchased a Makita 8391DWPETK 18V Cordless Combi Drill - how do i actually put a drill bit in? Do I need to take off the plastic ring?
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
Feb 25, 2012 | Makita Drills
How do i remove the chuck from a Makita 8391D
I think you will find that if you open the chuck fully you will see a cross head screw inside the chuck which you need to undo before removing the chuck. this secure the chuck from unscrewing while being used in reverse to undo screws. Once this screw is out a spanner is used at the base of the chuck to unscrew it from the shaft. this may need a short sharpe shock to get it to move.
Jul 31, 2010 | Makita Drills
How to change drill chuck for makita hp 2040
if its a reversible drill there will be a screw in the bottom of the chuck, open the jaws as far as they will go and you should see a screw head, it is a left hand thread so put the drill in low speed selector this will stop chuck turning as easily, then turn screw clockwise as your looking at the chuck, when its out put an allen key in and tighten up the chuck hit with hammer now in a anti clockwise direction it should unscrew. repeat in the reverse procedure to fit new chuck....
Jul 31, 2010 | Makita & 1/2 Inch Drill
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
Damaged chuck
Grasp chuck, reverse it until fully open. Look inside where bit goes and should be an allen head or torque head screw holding chuck to motor arbor/shaft.
May 14, 2009 | Makita 5/8" 2 Spd Hammer Drill
Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
May 04, 2009 | Makita Drills
Makita 6408 drill motor. can't see how to replace the chuck.
If you have the 6408 as listed the spindle is threaded and you are correct there is no retaining screw. What you would need to do is find a bent handle allen wrench about the size of the chuck capacity 3/8" and insert the shorter end in the chuck and tighten. put the chuck on a block of wood or workbench and position the long end at about a 30 degree angle in the counter clockwise position and strike it with a hammer, this might take a couple hits. If this is not a 6408 let me know and I will look at the tool for you and see what you got.
Jan 23, 2009 | Makita 6408K 3/8" Variable Speed,...
Can't get the keyless chuck off cordless Makita 6095D drill.
If this is a newer tool it is probably a Torx drive screw usually a T20. The screw is LH thread and after removing it you will need to put some screws back in tool to remove the chuck. First shift the gear selector to the low setting and the clutch to the drill only. Next get a bent handle allen wrench about the capacity of the chuck install the short end of wrench in chuck and tighten. Put the chuck on a block or wood or a workbench to support is and turn the wrench to about a 30 degree angle in the counterclockwise position. The chuck has standard threads so you want to hit the wrench with a hammer to loosen it. This might take a few tries but it will work. Good luck
Dec 31, 2008 | Makita 12V Cordless Impact Driver -...
Makita 6405 3/8
according to my breakdown its a drill. do you checked if there is a screw inside the chuck. if there is one remove it by turning the chuck fully & insert allen key 5/16 or 3/8 short side to the chuck.tighten the chuck & wak the allen key with a hammer counter clockwise. do it again if required.putting back together the other way.
Jun 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
597 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
