Question about Casio PhoneMate PMP3875BK
My Phone Mate Model PM5851 Does not have a dial tone. It sat in it's holder all day and when I came back in the evening there was no dial tone. You can't call out and no one can call you.
How do I get a dial tone?
Is the base station plugged into the phone jack on the wall?
May 17, 2014 | Swissvoice Epure Full Eco Cordless...
GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
May 21, 2008 | Uniden Cordless Phone
When I dial out on my Vtech phone, it goes back to a dial tone or a busy signal
Are you sure that the phone is even trying to dial? Push 1 digit and make sure dial tone is going away. Could be bad dial pad.
Apr 05, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
Hi I am trying to get a dailing tone but nothing is happening
Firsst of all check the line to the base phone, test with a good phone for confirmation or test the voltage of the line. next clean the surfaces of the handset contacts to the base. check if the battery of the handset is good. if not replace. Next placing the phone on the base should make it detect the base. If the base and the handset does not mate, then you will not get the dial tone. this could be due to failure of the inout due to lightening/ thunderstorms, failure of the optocouplers, the dial switching ICs or the main processor. You will need to check on these electronic sections. I hope this helps. Good day
Jul 12, 2010 | Panasonic KX-TG1100 Cordless Phone
Phone went from touch tone to pulse. . .
Read the manual to reconfigure that option. (Look for Setup button on the phone) I can't guess what model you have. On older phones one could find a switch on the the phone to flip between Tone and Pulse.
Sorry I could not be of much help.
Sep 04, 2009 | Uniden Cordless Telephone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
I turned the ringer off on my phone and now theres no dial tone.
Unplug the phone entirely for about 5 minutes and then plug it back in and see if this works.Good Luck!
Apr 15, 2009 | Vtech IA5854 5.8 GHz Cordless Phone
Phone has a dial tone but will not dial
I would first verify that the line is good. Take a known good corded phone. YES corded phone !!! and try dialing with it and make sure it dials on the line every time. Also make sure that the Pulse/Tone setting is set for your service( there is still a few area without Touch Tone belive it or not)
Once you verify that the line is ok check each phone and take the defective ones back to where you bought them.
Dec 26, 2008 | Lands Phones
Uniden TCX805 Cordless "loses" dial tone
Sounds like the switching mechanism that creates the link is stuck. When you answer your phone, you allow the voltage to complete it's path and you either answer the phone or you hear dial tone. If that switch is stuck closed, even though you hung up the phone, the connection is still alive. When you try to pick the phone back up later, the connection is still closed, but your phone has already passed it's "if you would like to make a call" message and you hear no dial tone. Unplugging the power to the phone resets this switch and all is good again.....that is until it gets stuck again. I have seen this problem with phones after a near lightening strike at the house. Sounds like you need to get a new phone as I don't think this is repairable.
Dec 30, 2007 | Uniden Cordless Phone
Casio PhoneMate PMP3875BK Logo
91 people viewed this question
Top Casio Lands Phones Experts
Patrick Tinashe...
JonSnell Electronic
JonSnell Electronic
Tom Chichester
Are you a Casio Lands Phone Expert? Answer questions, earn points and help others
