Question about Janome 6019QC Mechanical Sewing Machine
Need help with automatic buttonhole for my Janome 6019. How do I use it?
  • 2pence May 01, 2009
    I have lost my instruction book and presumably because I am in the UK, the brochure request form will not work for me.
Right, now I've figured this out :)
Put your button in the holder on the foot - fiddle about with it enough and I'm sure you'll work out how, one bit slides open and then you can close it again to hold the button.
Then fit the foot to the machine - the piece with the button in goes at the back.
Select 2 on the stitch selector, 4.5 on the stitch width and buttonhole on the stitch length.
Using scraps make up a piece of fabric with the same number and construction of layers as your finished garment and do a practice run or three.
You can set the actual feed length using the -.+ control (beside the feed release switch at the front, below the sewing table).
Between button holes you need to reset by turning the stitch selector wheel slightly until you hear a click.
Once you're happy with the method, think you have the settings as you want them and feel you have done enough practice try it for real on the garment.
Note: the button holes come out a bit long - just don't cut down the whole length or you may need to hand sew them tighter.
Posted on May 01, 2009
    I realise I have left out a very important step in my previous posting.
    Once the foot is fitted to the machine you need to pull down the button hole bar which is the bit that makes the button holer stop when it has got to the required length, do the long stitches at the far end and then work back up the other side. It is a metal bar with a plastic tab on the end embossed with a button hole symbol and pulls straight down on the left-hand side of the foot from inside the machine above the needle holder.
    I found the left side of my button holes was closer stitched than the right so I did the left side with the adjuster on the . [dot] and switched it to - for the return side.
    Master:
  • 492 Answers
Try
Machines Support
For questions regarding Machine Support, fill out the Machines Support Form or call anytime, Monday through Friday 8:30AM – 5:00PM EST, 1-800-631-0183, ext. 774.
Technical Support
For questions regarding Technical Support, installing, updating, or using your embroidery software, fill out the Software Support Form or call anytime, Monday through Friday 8:30AM – 5:00PM EST, 1-800-631-0183, ext. 775.
General Inquiries
For general questions, please use the General Inquiries Form.
Request a Machine BrochureFill out the Brochure Request Form to request a brochure for your choice of machine.
Janome Mailing List
Click here to join the Janome Mailing List.
this:
Posted on Apr 30, 2009
How do I sew a buttonhole on Janome 6019
most likely by setting the machine to that function ..rereading the instruction manual would be my first option .
Jul 31, 2015 | Janome 6019QC Mechanical Sewing Machine
I can not get the automatic button hole to work properly on my Janome 6019.
Hello what is the machine doing
for example i have a 5018 with mine there is a lever at the back to pull down which when it finishes half it stops and resets itself to complete the other side and stops when complete but need the button in the compartment to guide for sizing
i will do a video clip on my channel send more info to mysteria21@gmail.com
Feb 25, 2015 | Janome Sewing Machines
Cant get my janome excel mw 3018 to do an automatic buttonhole
I would suggest taking the machine back to where you bought it & letting them show you how to make a buttonhole or getting another
machine
Aug 21, 2012 | Janome Sewing Machines
Janome 3050 shows bl when i make button hole
bl stands for buttonhole lever--the buttonhole lever is to the left of the needle bar---pull the buttonhole lever down as far as it will go & when your done just push it back up
Sep 20, 2011 | Janome DC3050 Computerized Sewing Machine
I cannot remember how to use the buttonhole function
try one of these other solutions, there are 4 on buttonholing with Janomes
http://www.fixya.com/search.aspx?cstm=0&_s=janome+buttonholer+foot&miniask_sbmt=1&ta_message=
just copy the link into your browser bar if it doesn't take you there automatically.
usually there is a little lever you pull down on the left of the pressure foot which triggers against the buttonholing foot to get the right length buttonhole.
Jun 18, 2011 | Janome Memory Craft 4800QC
Excell 11 Buttonhole Instructions
if you email me on lisadino@bigpond.net.au I can send you the scanned pages
Mar 30, 2009 | Janome Sewing Machines
Can't figure out automatic buttonhole use on MC4000
2 things must do:
You have to use the buttonhole foot.
You have to pull down the lever to the lowest position (just left of needle bar/ presser bar up in machine.)
Set to buttonhole. After each buttonhole, be sure to change off the buttonhole then reset to buttonhole to reset the buttonhole to the beginning
Mar 15, 2009 | Janome Memory Craft 4000 Sewing Machine
I keep getting the bl sound when trying to make automatic button
I'd forgotten to pull the little lever down that abuts onto the buttonhole foot! Simple!
Nov 28, 2008 | Janome Memory Craft 9000 Computerized...
Janome 6019QC Mechanical Sewing Machine Logo
537 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
