Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
How do you take the top off a Whirlpool top load washer. It is leaking like crazy from top somewhere. Suspect mixing valve, but can't see. Need to take off top to look.
In the front ,in the seam, with a flash light, on each side aproximently 4" from each side, you will need a putty knife or thin screwdriver to push inward, two clips , best one at a time with screw driver hold that side up then do second, then raise lid.
hope this helps
Posted on Mar 04, 2009
Whirlpool Cabrio Platinum water is coming back out of the hot hose
You have a hot , cold and a mix valve ,I would suspect that the mix valve is stuck, try tapping on it
Whirlpool W10372095 Valve AppliancePartsPros com
May 26, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
We have to turn the water on from the wall to get the machine to work, then afterwards, we have to cut the water source off if not, it will keep running.
One of the solenoids in the fill mix valve is stuck open. The mix valve will have to be replaced.Its a fairly easy repair on a top load and the part is about fourty dollars.
Sep 16, 2010 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool WTW5300VW2 washer hot water pipes shake during fill
Good day,
The only test on the water valve itself, is to replace it. The term is
"replace with a know good part", but may or may not work.
It is very possible you mght need a plumber to install a riser on the hot water line somewhere betwen the tank and the line going into the washer. The riser creates an air cushion in the line that is used on many issues much as you described.
It could well be best to call a few quality plumbing companies, to see if they have dealt with that issue.
Jul 13, 2010 | Whirlpool WTW5300SQ Top Load Washer
Top Load Ultimate Care 2 Just below the lid in
This problem is commonly caused by a water inlet valve (also known as a mixing valve) leaking by. If you live in an area that has hard water, or if you use well water, sediment, rust or calcified deposits can accumulate in the inlet valve and cause it not to close properly. Usually when they start leaking, you need to replace them. The following link explains how to access and replace the valve:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
If the model number is correct, the part number for a replacement valve is 285805.
If you have any questions, please post back and let me know. I hope this helps you.
Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool 9100 lw2: water does not shut-off, i have to shut off water valves on hot & cold side after each use. The latest problem is the water did not shut off at all & flooded the laundry room.
your water mixing valves are leaking by
this is a very easy repair
three screws keep the top down on the back
slide the top backwards then lift
the water valve is right there on the back wall
call apliance parts pro
877-477-7278
order part number AP3128776
41.00 a few dollars cheaper than sears
Oct 14, 2009 | Whirlpool GHW9100L Front Load Washer
Need to get into the water mixing valves on Whirlpool washer
with putty knife press in clips at each corner of console and lift up ..also press same type clips at front edge of top about 2-3 ins in from each corner
Nov 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Whirlpool top loading washer Model # LSR8233EQ0 that the water mixing valve needs to be replaced. How do you get to that valve? Do you remove the back of the machine or go from the front?
Do not remove the back.Take 2 screws off front ends of console and pull slightly forward and flip it up- it is hinged on the backPop off two spring clips that engage cabinet. Unplug lid switch wire. Tilt cabinet forward and the whole thing comes off. Thanks, please leave feedback or contact me again for more info if you need it.
Kenmore 80 series
suspect sand/rust has gotten past screens inside water valve or screens are missing allowing residue to get into valve ..replace valve ..clean screens as needed in future but be sure to reinstall
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Fill switch cutoff
remove the 2 screws on rear of console pull console slightly forward and roll it up and back..ck small hose to water level switch to be sure it is on..is water stopping when control knob is pushed in?? if not suspect inlet valve replace it ..if it does suspect water level switch or that hose also hose may have small hole in it somewhere or be pinched
Aug 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer leaks on on the floor when using a large load setting.
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Jul 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
442 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
