Question about Canon PIXMA MP780 All-In-One InkJet Printer
Canon pixma mp780 printer will not turn on!
After replacing the black inks the printer would not turn back on? my wife says she smelled something burning and turned it off! and we could not turn it back on? i thought it was the ink that smelled?
  • Canon Master
  • 419 Answers
It's possible that the printhead has burned out and in the process it's blown the printer in the process.
You can try one trick that has worked for me in the past but it's by no means guaranteed.
- Disconnect the printer from the mains/power socket!
- Remove the cartridges and printhead
Work out how to remove the left panel (left when looking at front) and then identify the power pack which is like a module that plugs into the printer.
Into this power pack goes one or two small internal connectors which you should disconnect, wait 10 seconds and then reconnect.
Push the power module back into position if you've had to release it, and then try plugging the printer back in to the mains/power-socket and try turning the printer on.
If it DOES comes back online, you should get a brand new printhead ASAP.
IMPORTANT: DO NOT use your old printhead as it will blow the printer or any other printer that it is installed in.
If it doesn't come back on then it's toast and it's time to look for a new printer.
I suspect you will find the printer is dead but if it does come back online you'll have dodged a bullet that took my MP750 and iP4000 to printer heaven. The fix above worked for a couple of iP4200's and an MP500 so it could still be ok.
Good luck.
Posted on Mar 03, 2009
Hi, How do i check ink levels of canon pixma mp780? How to know when to change cartridges ? thanks in advance. Amit Bhatt
Your Canon MP780 will have the ink levels displayed on the screen.
Also, while printing on the Canon printers you would usually get a window on the screen showing you the level of ink in the printer.
And here is a link on how to replace the ink cartridges on your printer
Dec 16, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP780. Recently my color ink
Have you checked to see if the jet area on the bottom of the ink cartridge has a blackish sludge on them? It might be that the area that the print cartridges are purged/cleaned to one side of the printer (sometimes called a service station, or spitoon) has built up excess ink that has gotten thick and high enough that as the carriage goes over that area the bottom of the cartridge gets polluted with the blackish sludge. It will work slightly into the jets where the ink comes out and cause discoloration, even after you change the color cartridge. Open the unit to look inside with a flashlight for build ups and clean it (if you find some) with disposable things like cotton swabs, coffee stirrers, whatever you have that wont damage anything inside. Another cause could be mixing of the cyan and magenta and yellow somehow inside making a dark color representing black - but replacing the cartridge would cure it immediately.
Jun 19, 2010 | Canon PIXMA MP780 All-In-One InkJet...
My Canon pixma MP780 is flashing a message that the waste ink is full. What does this mean and how can I fix it?
Have to reset the waste ink counter & replace with new WASTE INK ABSORBER KIT. Only service centre can do the service job.
May 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Whenever I replace the 3E black ink in my Canon MP780 printer, the printer quits printing.  I have tried all the cleaning remedies on the menu.
because the print heads are gummed up with old ink and need to be cleaned with some alcohol and an old rag. do not get the ink on your fingers its hard to get off...good luck...
Nov 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma mp780 printer will not print colors
I just bit the bullet and went out and bought Canon ink and replaced all my other Print Pal ink cartriges and my printer works like a charm again.
May 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My Pixma MP780 is suddenly printing VERY slow...
The speed of the printer could have a lot to do with the settings for photo quality. If you've cleaned it out completely and the settings for your quality still make no difference in the speed, you've damaged hardware that will have to be replaced... replacing the entire printer is usually the best option at that point.
May 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
when they say TONER , its refering to the INK CARTRIDGES , Color & black ,
CANON PIXMA MP780 & MP750 uses the same INK CARTRIDGES :
BCI-3eBK for BLACK & BC-31C for color
please rate this solution , hope this helps
May 01, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
1,025 people viewed this question
old marine
old marine
