Question about Epson Stylus CX4400 All-In-One InkJet Printer
New ink caretridges not getting accepted by epson stylus cx4400
I have epson stylus cx4400.I have bought inks from epson and when ever I load these inks, I get a message that cartridge is empty.I bought more new ones, still the same results.I removed the program and installed it again still no luck, help me!
  • quest_life Mar 03, 2009
    rouseinator,
    Tried that....still not working, any other ideas?
  • 24 Answers
Try removing the cartridges and cleaning the metal contacts with alcohol where the carts sit
Posted on Mar 03, 2009
  • 1 more comment
  • Michael Rouse
    Michael Rouse Mar 03, 2009
    I have only one other solution. Use a chip resetter, as these carts are a smart chip design and sometimes aren't properly "chipped" from brand new
  • Michael Rouse
    Here is the link for one:
    http://cgi.ebay.com/CHIP-RESETTER-For-Re...|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A0|293%3A1|294%3A50
  • Michael Rouse
    That should solve you problem
I have replaced the inks but still getting empty ink warning
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Epson Stylus CX4400 All-In-One InkJet...
PLSE HELP IM TRYING TO PRINT BUT NOTHINGS HAPPENING, IT IS ALL SET UP
test the printer first, so that we can isolate the issue. print a nozzle check to eliminate the possibility that the nozzles are clogged by dried inks. if nozzle check prints blank page or it printedr but w/ gaps or breaks, do head cleaning
Check the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus CX4400 Series. 3. Hold down the cx4400_ug.1.79.1.jpg Stop button as you press the cx4400_ug.1.79.2.jpg On button to turn the Epson Stylus CX4400 Series back on. Hold down both buttons until the cx4400_ug.1.79.3.jpg On light begins to flash, then release the buttons. cx4400_ug.1.79.4.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. cx4400_ug.1.79.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Clean the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Hold down the cx4400_ug.1.80.1.jpg Stop button for at least 4 seconds to start the cleaning cycle, which lasts around 1 minute. cx4400_ug.1.80.2.jpg The cx4400_ug.1.80.3.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus CX4400 Series during a cleaning cycle or you may damage it. 3. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 2 times. You can also turn the Epson Stylus CX4400 Series off and wait at least 6 hours. Then try printing again.
Feb 15, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Epson Stylus CX6000 Won't Load Paper.
hmmm am afriad if u had a warrant for it just take it back to them and get a new one...plastic staffs are hard to fix.
Nov 03, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Hi expert of ESPON CX4400 machine: after I did change a new black ink pack on it, why the on and ink light flash so i couldn't let it work?
Ink cartridge is not seated. Take it out and push in until you hear a click. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Aug 04, 2009 | Epson Stylus CX4400 All-In-One InkJet...
How do I change the ink cartridge in the epson cx4400
hi, i have retrieved a the manual for you. this is a main link to a bookmarked page where you can access every piece of literature you need form troubleshooting and manual downloads and quick guide instructions on how to install your cartridges.
Click here togo to this page.
Mar 06, 2009 | Epson Stylus CX4400 All-In-One InkJet...
I need to refill my ink for a espon stylus cx4400 printer, don't know where the hole is located at the top to put the ink inside
Epson have designed their cartridges so that refilling is virtually impossible. Believe me a LOT of money has gone into this so I would forget about trying to refill your original cartridges.
Instead I would recommend locating a reseller for refillable cartridges with a resettable chip... Also, be very careful buying any old ink as there are some very cheap, poor quality inks available which are more likely to clog your printhead and drive you crazy. Good brands to consider are Image Specialists, hobbicolors and OCP but there are others out there.
Hope that helps.
Mar 02, 2009 | Epson Stylus CX4400 All-In-One InkJet...
On light flashing and stop light flahing
You might want to try a chip resetter as these carts are a smart chip design. Heres the link for one:
http://cgi.ebay.com/CHIP-RESETTER-For-Reset-EPSON-7-PIN-9-PIN-ink-Cartridge_W0QQitemZ290285956034QQcmdZViewItemQQptZPrinter_Accessories?hash=item290285956034&_trksid=p3286.c0.m14&_trkparms=72%3A1234|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A0|293%3A1|294%3A50
Nov 09, 2008 | Epson Stylus CX4400 All-In-One InkJet...
Changing ink
You need to clean the nozzle and there is a procedure from the printer properties menu on how to do this.
Jul 03, 2008 | Epson Stylus CX4400 All-In-One InkJet...
Cartridge changing
You can download the manual from the link below: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=41664&prodoid=46253282&category=Products Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 02, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX4400 All-In-One InkJet Printer Logo
312 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
