My advanced auto service details noted that I should have changed my crankcase oil filter a few thousand miles ago. Where is this located and how do I do it? Is this something I can do myself?? Thanks, Melissa
SOURCE: want to no where oil filter is located
it is on the back side of engine if you stand on the passenger side look down the back side of the engine you might not notice it it is hard to see from up here
SOURCE: Changing oil in a Ford 450 super duty motor home
Places that service motorhomes want to make the bigger bucks. Do it yourself. Its just a drain plug and filter removal. They have a large oil capacity but if you have changed oil before on other cars go ahead and do it. If it sits high enough off the ground you will not need to raise it. Get a good oil change pan that holds 8 quarts. It may take that much.
SOURCE: where is the fuel filter located on a 1992 ford
it is under the car in the rear near to the fuel tank, round cannister.
SOURCE: Ford Focus TDCi Service
it depends on what oil filter you have fitted on your car if you have the screw on type it woud be at the back of the engine on the offside.and the other filter sounds like its the pollen filter. hope this helps
SOURCE: 2001 ford taurus 3.0(2) codepo174, changed oxygen
Welcome to FixYa.com
My Name is Lee Davidian
And i need to ask is your 3.0 liter engine a Flex fuel? Vin # is the eighth digit is it a 2 or S??
Is this just a regular oil change?? lol
Example: you drive 14,000 miles a year You change your oil 4 times a year,that is 3,500 miles between changes & every 13 weeks, drive more than that you change oil 5 times a year
