Question about Toshiba 61H71 61" Rear Projection Television
61H71 no picture no sound and power led is blinking, When plugged, it makes couple of clicks and issue continues. I did have some convergance issues but never repaired it. Any direction to DIY fix appreciated. Thank you
  • 1 more comment
  • Pokesh Mar 04, 2009
    61H71 no picture no sound and power led is blinking, I have unplugged to reset for more that 24 hours and fix. When plugged, it makes couple of clicks and issue continues. I did have some convergance issues but never repaired it. Any direction to DIY fix appreciated.
    Thank you
  • Pokesh Mar 05, 2009
    61H71 no picture no sound and power led is blinking, I have unplugged to reset for more that 24 hours and it fixed nothing. When plugged, it makes couple of clicks and issue continues. I did have some convergance issues before but never repaired it. So today I changed both IC's (stkSTK392-110)but the problem still continues. Any Suggestions appreciated.
    Thank you
    Ya sure
  • Toshiba Master
  • 19,396 Answers
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem on dvd with no receiver box connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Commonfaults that can occurr suddenly are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
check also the video cable, if the cableis shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Check also connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Mar 09, 2009
    Scholar:
  • 165 Answers
Due to convergence problem the main board got shorted .get the replacement board ffrom www.partstore.com
Posted on Mar 05, 2009
    Sergeant:
    Novelist:
  • 277 Answers
As you said before you had convergence problem before ,but you still continued using this further this may have damaged the other parts or most probably the main board of the tv.
check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
also if its main board replacement then going for new tv is worth getting.
  • 10,594 Answers
If you want to repair TV yourself then should have relater Service Manual, Digital Volt Mmeter, soldering tools, electronics knwoledge etc.
You can get service manual of 61H71 from Manual Zone for small fee.
You can buy required parts from Parts Store.
Need further help, let me know.
Posted on Mar 03, 2009
  • 6,784 Answers
Hi, the first suggestion would be to rebuild or replace the power board. the second would be to preform a break point test on all circuits. last, i would replace the convergence as well. the red light is signaling a power board failure. the clicks you are hearing are also from the power board. its malfunctioning.
  • Toshiba Master
  • 13,433 Answers
A service / repair manual should have information on the blinks and explain why and what is wrong and what to replace.
https://www.manualsparadise.com/ShowProductsForModel.do?model=M89465532
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
  • SAM ANDERSON Mar 05, 2009
    Did you replace resistors and capacitors along with the convergence IC s .
    Also did you replace one IC or did you replace both convergence IC ?
    If you replaced one it wont work . You need to replace both convergence ICs and also you need to replace capacitors and resistors along with it .
    You need service manual for this operation to check the bad capacitor and replace it .
    Hope this helps .
Vizio e420vse doesn't power on when plugged in. Is this a power supply issue, a main board issue or LED driver issue?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 13, 2014 | Televison & Video
Toshiba TW40H80 40"
ok! maybe you have defective convergence correction circuit! sir do you have experience in electronic repairing?
Oct 11, 2007 | Toshiba TW40H80 40" Rear Projection...
The Timer/Standby LED light is flashing on the front of the TV. Can turn on TV with sound but no picture, TV shuts off within 5 seconds.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Aug 08, 2011 | Sony Grand WEGA KDP-65WS550 65" Rear...
When i turn on my tv the little red light blinks. THen the sound comes on but no picture. After a couple of seconds the red light starts blinking again and the standby light comes on and then nothing.
Jul 16, 2011 | Sony KP-51HW40 51" Rear Projection...
Red standby light came on and no picture sound is ok .Next. time tv came on it played approx one hour everthing ok. then the picture gradually faded away . Red standby light came on again. Still no...
Jul 08, 2011 | Sony Televison & Video
ICs + resistors swapped= blue power light auto on clicking noise
Unplug the power to the convergence board. If it turns on, you still have a problem in the convergence circuit.
Dec 16, 2009 | JVC AV-56P575 56" Rear Projection...
I have a sony bravia 60'' projection tv kds-60a3000. the problem is after a couple of minutes i will get no sound or picture. i disconnected the plug from my power strip for 5 minutes to cool down, then...
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. Unplug the television power cord from the electrical outlet.
  2. Let the television remain without power for 60 seconds.
  3. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  4. Turn on the television.
Sep 22, 2009 | Sony Televison & Video
Toshiba model 61h71 red light comes on /no picture or sound
We had the same problem, open the panel on the back of the tv, the board on the left, not the one with the convergence chips. Inside the tv u will see a piece of paper with the fuse info. The board on the left unscrew it and flip it away from you, the fuses to test are at the bottom, on the circuit board it will say 125volt 5 amp, and the number starts with an f. they are small and rectangular and black. Check all but the 3 at the bottom are usually the culprits Hope this helps u
Jan 14, 2009 | Toshiba 61H71 61" Rear Projection...
Sony KDP-65S550 red light keeps blinking
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Jun 28, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Blinking power light
Our 61H71 just did the same thing! I have found on another site where a fuse on the Convergence board was replaced as a fix for this issue...however, fuses are usually symptoms not causes...it is very difficult to find availabe information on this issue...it may be time to call a professional...Good Luck!
Nov 18, 2006 | Toshiba 61HX70 61" Rear Projection...
Toshiba 61H71 61" Rear Projection Television Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
