Question about Refrigerators
My side by side whirlpool ref. doese not cool or freeze even though the motor continues to run.
  • 400 Answers
If it is not cooling in either freezer or fridge and the compressor is running you are more than likely short of refrigerant which has leaked out. The leak needs to be repaired and the fridge recharged. If there is slight cooling you should make sure that the fans are operating and that you have airflow.
Posted on Mar 05, 2009
Side by side refrig/freezer not cooling
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Whirlpool GS6NBEXR Side by Side...
Motor sound in frig is very loud
HI,
you can check first this suggestion.
any further question let me know.
thanks,
Mar 28, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Freezer quit freezing
HI,
you can try this suggestion first.
thanks,
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator not cooling although lights and sound are OK
your condensor had been chocked therefore the gas is not circulating. contact your service authority..... as because it cannot be done by your self.
Feb 27, 2009 | Whirlpool ED2FHEXN Side by Side...
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerator side is freezing contents
If your settings are right then the cold control switch is the problem
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by side not working
Make sure the compressor is running and not just a fan motor.
Unplug the ref for 30 min or so and while you are behind the ref plug it back in, listen for the compressor to start. If you hear a clicking noise and the compressor never starts then replace the relay on the compressor. If the compressor runs and still does not cool then you may have a coolant problem.
Dec 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
FRS26KR4CB1 side by side refrigerator
It sounds as if you have a defective compressor start relay.  It is located on the side of the compressor, usually contained within a black plastic housing (box).  If ordered, it will most likely come with an overload proctector.  Change both parts.
Oct 13, 2007 | Whirlpool ED0GTQXMQ Side by Side...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
