Question about Philips HTS-3555 System
Occasionally, when watching dvd, thru HDMI the picture clips out.
The unit seems to be not displaying some parts of the dvd. I can hear the sound continue, but it takes about 10 secs for the pics to come back. Then it may go out again. I have tried with may dvds.
What sometimes helps is when I lower the output resolution on the HDMI preferences. I have a TV that is full 1080p with several HDMI ports so I assume that it is not the ports.
Any clues?
  • 51 Answers
Yes you are right, this may occur due to display section problem, so please check the display section on your dvd player to resolve your issue.
Posted on Mar 20, 2009
My Denon 301 has no picture but sound thru hdmi connection. Only works on scart lead
Try lowering your source input like DVD or playstation video display settings to a lower setting. Try a higher qualty HDMI cable.
Last the HDMI input port might be faulty
Oct 23, 2015 | Televison & Video
How do I get picture back on TV which was working the night before, which is hooked up to HD cable box, thru HDMI?
OS info is always helpful, if say you are running some type of nix, it's likely not getting recognized by xserver or if your running some version of windows your display manager has shut it down because of a resolution mismatch.
May 26, 2014 | Amstron Fujitsu LifeBook E390 Laptop DC...
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Audio Players & Recorders
Bose GS 321 HDMI issue. I've had this unit for 6 months using the HDMI connection from the Bose to my HDTV for watching DVD's and its been working without issue. Last week I try watching a DVD. I change...
Hi, did you manage to fix it? I have the same problem. Would appreciate if you can share some results if you have any.
Many thanks, Jeffrey
Mar 08, 2010 | Bose 321GS Series II System
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
TV has sound, but no Picture
Does your sound go thru the tv or a sound system ??? when ya turn tv off then on does it show anything like its coming on ??
Nov 16, 2008 | Curtis-Mathis CM19011 TV
Sound problems with Insignia Flat Screen 37
It may be that the set is set for alt sound. go to the menu and set the audio to stereo. If the audio is set wrong it thinks you are set for spanish and if the broadcast is not in an alt language there will be no sound.
Jul 10, 2008 | Televison & Video
No picture, but sound
I had the same problem and I managed to solve it. It was because the HDMI was set to 1080i and my TV isn't HD. Default HDMI is 480p. You can check your current HDMI setting on the front panel of your DVD. There should be a button with the words "HDMI select". Next to it there should be 3 values. If the current one (a green light shows which one is selected) is not 480p, change it. To change it, make sure your sd-5000 is on, but not reading a DVD. The press the "HDMI select" button on the front panel until the selected one is 480p. This worked for me.
(I had the same same problem without the reading slowly part. On one TV, the sound and video weren't working, and only the video wasn't working on another TV)
Hope it helps.
Dec 28, 2007 | Toshiba SD-5000
HDTV picture staticky, cuts out
I suggest contacting Sharp directly. I just did and received absolutely nothing from them. But if others such as myself who have the exact same problem as you ( I own a LC32D40U just over 2 yrs old) contact then maybe something can get done.
I will certainly NEVER recommend a Sharp product to anyone and will as of this moment respond to every message out there letting everyone know exactly how bad Sharp's product are. I would recommend the Sony XBR series to anyone looking for an LCD television.
Dec 03, 2007 | Televison & Video
Sound, but no picture
The hdmi inputs on this unit go directly thru the main digital pcb. and the component inputs feed thru the av pcb then to the main pcb. If the composit hook up do not work and hdmi inputs do work the unit has a bad AV pcb.
Nov 08, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Philips HTS-3555 System Logo
120 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
