SL-D210 sound only plays from right channel speaker
SOURCE: turntable technics sl-bd27
You have 4 wires coming from the needle pickup to the cables which connect to the amplifier/receiver. I would check the needle, the pickup unit, and the leads from the pickup to the cables. You can probably run a continuity test or ohm test for verification. If that checks, pickup and needle is your next step.
SOURCE: Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm. Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo. I'm betting the pre-amp is bad.
SOURCE: Poor quality audio from a new Grado Black series cartridge
Look around for a bad conection, perhaps inside the turntable.
SOURCE: Only one channel plays.
If you disconect the wires to the cartridge and with deck plugged in to the amp and switched on, you can touch the ends of the wires with your finger. Though there are four wires, only two should produce a buzz, one in the left, one in the right speakers. If you get a buzz in each channel, the rest of the unit is working fine and you have a faulty cartridge or a poor connection to it. If one channel remains dead, then you have a problem in the wires to your amp or an internal fault inside the deck. If internal I suggest you remove the bottom of the turntable and have a look around.
