Question about KitchenAid Kitchen Ranges
I have a Kitchen Aid free standing, purchased 2001
I have an Electric 30" Kitchen Aid Superba free standing, purchased 2001 Model # YKESC307HT4 range/oven with Ceran top. Problem: I started self clean part way through self clean stopped and door will not open after cool down. The board must be good as it still iluminates and allows me to try and reset clean but will not start clean cycle. Upon retrying clean cycle I can hear the lock try to relock and 20 to 30 seconds later I can hear a click under the front panel (approximately under clock display), after the click a code of F5 E1 displays in the clock location, upon touching Cancel the code disappears. To add to the locked oven problem none of the elements turn on, all were working prior to setting self clean mode. I am looking to try and repair myself. I have all handtools and meter to check.
All help will be much appreciated.
Gary
  • 2335 Answers
SOURCE: Kitchen Aid KGRA806PSS
Check HERE for more info.
Posted on Mar 03, 2008
SOURCE: Kitchen Aid Double Convection Oven stopped during Self Cleaning
same thing happened to me yesterday took all day to figure it out was the themal fuse on the back of the oven the part number for my kitchen aid is 8300802 if you want the doors to unlock and reset the display you can take the leads off the fuse touch them together and the door will unlock however it is best to change the part took me 5 minutes once i knew what to look for
you have to remove the back panel and you will see the part with the number on it cost me 50 dollars but better than the 8o bucks to have a sevice guy come and do it next time i self clean i will pull the stove away from the wall to help keep it from ver heating
Posted on Apr 04, 2008
  • 22 Answers
SOURCE: frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Posted on Mar 31, 2009
SOURCE: E1 F5 error on self cleaning oven
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.
This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at http://www3.sears.com/.
Before calling a repair shop,go to the circuit breaker box and turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
if not our suggestion would be to replace the part....
good luck...
if you got insight into your problem from us , A very helpful rating is appreciated for answering your question
Posted on Aug 10, 2009
taran_2005
  • 10515 Answers
SOURCE: slef clean message E1 F5
You have one or two possibilities here, one is your control board is going out. The second is that the Latch to the door, or switch is failing causing the clean door message.
The cheapest fix would be to inspect the door latch and switch to make sure it is making solid contact.
A POSITIVE RATING WOULD BE HIGHLY APPRECIABLE.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 06, 2009
Model 4ksm900b
Google Kitchen Aid in your home country.
Jul 30, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid superba architrend series s/s refrigerator purchased in 2001 when house built. Everything in freezer thawed today, pulled, took cardboard off back and cleaned with sweeper then replugged and...
Call someone to look at it. There is a fuse that can be replaced but I have no idea what was damaged. $200 repair if possible $85 tech visit if no repair possible
Jan 27, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
I have a kitchen aid superbra electric double
replace the left & right hinges ( if stainless door they have stronger hinges for this.. this is a very comm problem .. in some model you can use shim kit for this problem but replacing hinges is best avenue . mm
Dec 03, 2009 | Dryers
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid superba (electric oven)
you will need electrical meter. Take unit out of hole remove back plate( unplug or turn breaker off first). Turn power back on set temp for bake check leads to element. If no voltage replace control
May 27, 2008 | GE JBP69 Electric Kitchen Range
Kitchen Ranges Logo
77 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
