Question about Akai LCT2715 27 in. LCD Television
I replaced the lamp in my Akai dlp television. The red led still stays on, and i have a green line that shows up just on one portion of the screen. Help!!!
  • jackparish Mar 09, 2009
    I did what was suggested and it did not solve the problem. Still need assistance.
    Master:
  • 404 Answers
It must be a problem with the board or the power supply, check caps
Posted on Mar 03, 2009
  • 10,594 Answers
Please make sure that you replaced Akai original lamp for your TV.
Also recheck lamp door/ cover is fixed properly.
Let me know if you need further help.
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
  • SAM ANDERSON Mar 10, 2009
    You might have got defective lamp from Akai.
    Try with another lamp if you still get same red light then it tends to be the problem with the power supply board .
    You need to check the capacitors 1000uF/25v, 470uF/16v and 1000uF/16v on the power board . You need to check whether these capacitors are leaky or bulged .
    Hope this helps.
    For further help feel free to ask .
A red power, a green timer, and a red lamp led lights are flashing on t front power panel.
Likely an AKAI DLP made actually by Samsung. All 3 lights blinking is lamp failure. You can fix yourself with owner's manual.
Sep 29, 2014 | Akai PT46DL10 46" HDTV-Ready Television
Power and lamp lights flashing red and timer flashing green
Hi,normally when the 3 led lights show up they indicate its time to replace the lamp.The lamp that is inside your tv normally last around 3000 hrs 1-2 yrs .Pay attention to any weird sounds which could indicate another problem.
Dec 16, 2009 | Akai PT46DL10 46" HDTV-Ready Television
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
What is the oem lamp # for an akai model#pt5492s and where is the best place to purchase one?
Only DLP TVs have a lamp ,projection has 3 tubes red/green/blue. Call Encompass for power supply board, Akai is the same as Samsung.
1-800-638-3328
Sep 26, 2009 | Akai PT5492S 54" Rear Projection...
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
AKAI Rear Projection 46"TV has a blank picture with sound only
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
Please tell me more about your unit...
Thomas
Jan 19, 2009 | Akai LCT2715 27 in. LCD Television
My akai dlp tv is flashing power and lamp the red lights then to the timer is also flashing green light
the back cover is not on the TV correctly. on the back cover there is a safety switch so that the lamp light is not exposed. The lamp emits radiation and UV rays. Not healthy.
Dec 23, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Akai dlp
i have a similar tv, with 5 blinking red lights on the power off. is that a power board issue? (I see the small green light ionside the tv, flashing green.,,) the outer light stays red or flashed red when i power off. i replaced the fuses, still same issue.
Mar 18, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai LCT2715 27 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
