I have a Sony model kp53s75 rear projection tv and it will not turn on. (no picture or sound) The Standby light on the front blinks in 4 times. I have attempted to reset the unit by turning it off for an hour then plugging it in and it has not worked. The power fuse is ok. Do you have any suggestions? Thanks I have a sony model kp53s75 rear projection tv and it will not turn on. (no picture or sound) The standby light on the front blinks 4 times, I have tried to reset the tv by unplugging it for an hour and turning it on and off and nothing happens and yes there is power going to the tv. any suggestions? Thank You Rick rickeh32066@yahoo.com
  • rickeh32066 Mar 05, 2009
    I have a sony kp53s75 projection tv and it will not turn on the light on the front of the tv blinks 4 times and I have tried to reset the tv by unplugging it for an hour and hitting the reset button and still nothing happens this thing cost me 2200 dollars with the extended warranty,does anyone have any ideas of what to do, I called a place and they want about 500 dollars to start,is there a part or parts that I can get online and do it myself and save some cash so I do not have to just end up throwing it out at the recycle place,Help rickeh32066@yahoo.com
    thanks Rick, also is this a common problem that someone knows the part numbers needed and what the part or parts are called? Thanks again.
  • 173 Answers
Hi
In this case you have defective secondary oscillation for system thats why you cant see anything in picture and no sound.
Thanks!
Posted on Mar 05, 2009
    Sergeant:
  • 239 Answers
The projection bulb went out this happens alot with sony easy to replace. about 350$ for bulb you can do your self.
hope this helped
please rate well
  • 10,594 Answers
Please following parts in TV for 4 blinks error.
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
Let me know if need further technical help.
Posted on Mar 03, 2009
  • Shahid Electronics
    Shahid Electronics Mar 05, 2009
    If you are tech person then can understand easily what I told.
    I can help you out but since you rejected my solution and I do not know when you will see my comments.
    I have all tech info about your TV and can guide you step by step but it is very necessary that you should have electronics knowledge and repair experience.
  • 19,396 Answers
I think four blinks is a bad power supply or a convergence problem, I need to check the error code first.
  • Ginko
    Ginko Mar 03, 2009
    Hi, four blinks is a vertical deflection problem.
    You need to test the vertical deflection circuit. I report from service manual:
    Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I have a 51 in. Sony model kp-51ws520. when I turn tv on I get sound by no picture. Standby light blinks 5 times then shuts off . If I power it back on, sound no picture then standby blinks 10 times after...
Ck small blue capacitor next to hori output Transistor 2k volts they have been known to go Bad, if its OK replace Both of your STK ICs STK392-110s use 180s Mats has them 1-800-628-1118
Mar 23, 2010 | Sony KP-51WS520 51" Rear Projection...
My sony 50" wega just quit. No picture , no sound , no nothing ?
If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code.
And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it.
Still problem? let me know with exact model number of your Sony TV.
Thanks.
Jan 02, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
No picture or sound. standby light on front panel
The light is blinking a repeating error code. Try to determine the number of blinks before a slight pause as that will be an error code. Then respond to this same post and I will assist you with diagnosing what may be causing the set not to power up.
Dec 11, 2009 | Sony KP-46WT500 46" Rear Projection...
Ihave a sony KP53S75 TV there was apower surge and now there is no picture. The red light blinks 4 times can anyone tell me about this?
Hi, if this TV was hit by the surge and it was protected by a surge protector, please follow this reset procedure.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the problem is still there and the light is still blinking 4 times, this means that the surge has destroyed the Vertical deflection component. in this case, it will have to be replaced.
please rate and have a great day.
Mar 25, 2009 | Sony KP-53S75 53" Rear Projection...
I have a Sony model kp53s75 rear projection tv and it will not turn on. (no picture or sound) The Standby light on the front blinks in 4 times. I have attempted to reset the unit by turning it off for an...
Vertical deflection has stopped so IC509 ( vertical out) is defective or the vertical pulse buffer Q1505 is defective. That what cause the ledd to blink 4 times.
Aug 08, 2008 | Televison & Video
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony 57 inch WEGA Projection TV
Hi, this is a very common failure, you need to replace 2 IC chips on your power supply board, marked on the top of the IC`s is this number: MCZ3001D you can purchase them here if you are very proficient at soldering & un-soldering, and the board has to come out of the tv to do this, you might want to call a tv man for this one, but it will fix your set, happy holidays, BMW Rider
Nov 29, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony tv KP-57WS520
9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Sep 23, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
