Question about Refrigerators
Whirlpool side by side ref. Motor runs but ref. doesn't cool or freeze.
    Sergeant:
  • 239 Answers
Sounds like the compressor is going out even if it runs will cause cooling problem. new compressor costs around 350 dollars. better just to purchase a new fridge as it would cost more to repair.
hope this helped
please rate well
Posted on Mar 04, 2009
    Sergeant:
    Champion:
  • 237 Answers
This can be a few things one being if your refrig needs a freon charge. The other could be the thermostat is not reading the temp properly and needs to be replaced.
  • John Cole
    John Cole Mar 04, 2009
    also may be a compressor
  • Refrigerators Master
  • 19,396 Answers
It may be time to replace the compressor.
How old is the fridge?
  • Ginko
    Ginko Mar 04, 2009
    yeah ok, ask to the other guy he is the real fridge expert here, only bear in mind that your compressor is guaranteed .
    goodbye.
  • 13,433 Answers
It's not coolIf the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
  • Posted on Mar 04, 2009
    Side by side refrig/freezer not cooling
    if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
    thanks,
    Mar 28, 2009 | Whirlpool GS6NBEXR Side by Side...
    Motor sound in frig is very loud
    HI,
    you can check first this suggestion.
    any further question let me know.
    thanks,
    Mar 28, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
    Freezer quit freezing
    HI,
    you can try this suggestion first.
    thanks,
    Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    My side by side whirlpool ref. doese not cool or freeze even though the motor continues to run.
    If it is not cooling in either freezer or fridge and the compressor is running you are more than likely short of refrigerant which has leaked out. The leak needs to be repaired and the fridge recharged. If there is slight cooling you should make sure that the fans are operating and that you have airflow.
    Mar 03, 2009 | Refrigerators
    Freezer compartment of refrigerator not freezing
    First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
    So, how can the Ref side be cold and the freezer side not freezing?
    1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
    2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
    Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
    Refrigerator side is freezing contents
    If your settings are right then the cold control switch is the problem
    Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Side by side not working
    Make sure the compressor is running and not just a fan motor.
    Unplug the ref for 30 min or so and while you are behind the ref plug it back in, listen for the compressor to start. If you hear a clicking noise and the compressor never starts then replace the relay on the compressor. If the compressor runs and still does not cool then you may have a coolant problem.
    Dec 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Jenn Air ref/freezer not freezing/cooling
    Take the back out of the freezer and check and see if the refrigerator is in defrost while it is cooling if it is replace the timmer, then check and see if the fan on the underside is working if not replace the motor this will cause the problem also.
    If all that is ok feel the small line under the refrigerator ( high side) and see if it is hot while it is running if not check the freon in the refrigerator.
    Mar 03, 2008 | Refrigerators
    FRS26KR4CB1 side by side refrigerator
    It sounds as if you have a defective compressor start relay.  It is located on the side of the compressor, usually contained within a black plastic housing (box).  If ordered, it will most likely come with an overload proctector.  Change both parts.
    Oct 13, 2007 | Whirlpool ED0GTQXMQ Side by Side...
    Refrigerators Logo
    66 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
