Question about Refrigerators
GE profile refrigerator model PDS22SISALSS display
GE profile refrigerator model PDS22SISALSS freezer on bottom model: I hear clicks and then the digital temp display used to read and adjust the temp is blank. I'm not sure the clicks are related. I noticed it yesterday and later in the day the digital display was on but today it's gone again, and I did hear clicks. There's nothing in the manual about this.
  • Anonymous May 03, 2009
    I have the exact same problem! No ideas for a solution....
  • heliosxx May 20, 2009
    I've got the same issue, the thing with the ticks is it sounds a lot like it's trying to start the compressor but can't manage it. Eventually it starts. If you look carefully the ticks coincide with the lights dimming, not just the fridge lights, but the house lights.
the dr
  • 447 Answers
SOURCE: TFX24PRXBWW GE Profile Refrigerator - energy use?
I dont know how to locate these specs for you, modern refrigerators are much more efficient for a couple of reasons. Most new units have a Computer that controls the defrost cycle whereas older units have timers that defrost every 8 hours of on comp run time regardless of whether it needs defrosting. The new ADC (adaptive defrost control) can better monitor the frost on the coils to defrost less (in the defrost cycle it consumes 5x as many watts as when its cooling. Also most new refrigs, especially new GE units have much more efficient fan motors now also, however they too are computer controlled and when they fail they are expensive. Also the very high end new Counter depth models (in the $2500+ range) have a new variable speed compressor. This gives the compressor the ability to run at a low, med, and high speed, reducing even more the watts that will be drawn in normal operation when the fan motors are on low and the compressor too. If you have any other questions let me know ill be glad to advise.
P.S. Buy an extended warranty with any new appliance you purchase! Trust me!
Posted on Dec 05, 2007
  • 27 Answers
SOURCE: Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Posted on Feb 02, 2008
rogrrabbit
  • 986 Answers
SOURCE: We just purchased a ge profile refrigerator today,
You have to go into the Diagnostic mode to see if you can reset this issue or if the main board in back is bad. Here's how to do it:
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
First, run the control and thermistor test:
Control and Sensor System Self-Test (0 7)
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display. If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
Thermistor test results:
• P = Pass
• 0 = Failed
• S = Short to 5 VDC
• B = Bad amplifier
When testing has been completed, do the following :
• Enter code 1 5 to completely reset the system. Then press the Hold button (or any other button than a temperature button) to accept the code.
When you're done, unplug the refrigerator for 10 seconds and plug it in....if it does not run, the board is bad.
Posted on Jun 14, 2009
SOURCE: GE Profile - model PDS22 - constant clicking noise
Yeah, same problem. There are two capacitors that seem to be prone to going out. You can replace the main board, or (if you can solder) replace the two capacitors with slightly larger ones (radio shack mdl number 272-1030 works) just remember to bend them away from the heat sink if you go that route.
Posted on Jul 11, 2009
  • 288 Answers
SOURCE: GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Posted on Nov 27, 2009
Pds22sisalss seems to run all the time. Compressor run and turns off once in a while. Freezer willwarm up to 8 degrees then it will cool down in about 24 hours. Something is wrong..help
the machine should shut down and go into defrost,a heater comes on in the freezer that melts all the frost off of the evaporator coil,but if your food is getting soft in the freezer you have a computer board that everything runs through on this machine,also there's a sensor on the top of the evap coil,you have to look at it,if it has a black ring around it where the wires come out of it it has to be replaced,it looks like a bullet and the new sensors are alll white,also when you're in the back,remove the back bottom panel and clean out the condenser coil,if the coil is blocked with dust this will make the machine run hotter but like i said everything runs through the board,most likely problem board part number is WR55X10942 and the sensor part number is wr55x10025,go here and you can look up parts
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-PDS22SISALSS/0432/0161000/GR708132/00002?blt=06&prst=&shdMod=
Jul 14, 2012 | GE Refrigerators
GE refrigerator bottom freezer Model #PDS22MBSACC has been clicking for hours, is there something I can do to fix it, or do I need a new compressor? Also the refrigerator and freezer control numbers are...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 12, 2011 | Pds GE Profile Bottom-Freezer Drawer...
Have a GE Profile bottom-freezer refrigerator, model #PDS22MBSBWW, serial #RL053351, approximately 5 yrs old. It has recently started making a "clicking" sound which goes on for anywhere from 1...
For the clicking if the fridge has been off for at least 5 min. and clicks when it tries to start then it may be the start relay on the compressor . If it does not stay off for at least 5 min then it may be the control which may also be why your display is not working.
Nov 30, 2010 | GE Profile PDS22MBS Bottom Freezer...
Ge profile bottom mount and temperature control
sounds like the mother board maybe bad. we replace alot of those , or 2nd i would say a display board .
Sep 13, 2009 | GE Profile PSW26P Stainless Steel Side by...
My GE Profile bottom freezer and frig's temps are also up..help
has a FF error shown up on your display. If so that is your freezer fan, and if not it still might be the FF motor is running to slow.
Jul 20, 2009 | GE Profile Stainless Bottom-Freezer...
Clicking of Ge Model PDS22SBRBRSS; serial No; AHO45649
Replace the mother board. It is only a matter of time until you experience cooling issues.
May 26, 2009 | GE Profile PDS22MHR Bottom Freezer...
BLANK DISPLAY AND CLICKING SOUND
This is the main control board failing. My symptoms were identical (intermittent display and clicking), and eventually the clicking didn't go away and the freezer got hot. I replaced the main board yesterday and all is well (display fixed and no clicking). I was able to find the correct part number using the GE website (entered refrigerator model PD22S1S and then selected PDS22S1SARSS from the drop-down list). My part number was WR55X10656. The GE price was shown as $157.50, but I bought mine from ApplianceZone.com for $101.68. Hope this helps.
Dec 01, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
I HAVE A GE PROFILE FRIDGE, WITH BOTTOM FREEZER. THE DISPLAY WORKS SOMETIMES OTHER TIMES IT IS BLANK. ALSO EVERY NOW THEN I GET A CLICKING SOUND FROM THE COMPUTER BOARD IN THE BACK, SOMETIMES IT LAST FOR A...
This is the main control board failing. My symptoms were identical (intermittent display and clicking), and eventually the clicking didn't go away and the freezer got hot. I replaced the main board yesterday and all is well (display works and no clicking). I was able to find the correct part number using the GE website (entered refrigerator model PD22S1S and then selected PDS22S1SARSS from the drop-down list). My part number was WR55X10656. The GE price was shown as $157.50, but I bought mine from ApplianceZone.com for $101.68. Hope this helps.
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
289 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
