Question about Belkin F8E825 USB Mini Wireless Optical Mouse
Getting-my-wireless-mouse-to-work-on-my-laptop
    Problem Solver:
  • 5 Answers
If all else fails read the instructions. Updates should be automatic if you have updater
Posted on May 18, 2013
  • 1,602 Answers
WHEN YOU PLUG IN THE MOUSE AND THE WIRELESS USB CONNECTOR THERE SHOULD BE A BUTTON ON THE MOUSE AND ONE ON THE USB CONNECTOR, THE BOTH HAVE TO BE DEPRESSED AT THE SAME TIME SO THEY CAN GET IN SINK WITH EACH OTHER, I IMEAN THE SAME FREQUENCES SO THEY CAN COMMMUNICATE WITH EACH OTHER.
RODGANDYSR
PS GO ON LINE AND CHECK FOR ANY TYPE OF UPDATE OR CHANGES OR SHORT CUTS
Posted on Mar 05, 2009
USB port for wireless mouse gets hot vey fast and no longer works
I have seen power supplies going bad, killing many components, most especially anything connected via USB.
Dec 15, 2013 | Toshiba Computers & Internet
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
Trying to install logitech wireless mouse on Acer laptop with Windows 7 but not seeing the device. Wireless button is on and active on the laptop
Wireless button on laptop has nothing to do with wireless mouse. Plug in your mouse receiver that come with the mouse in to a USB port on your Laptop. Turn on your Mouse and hold the reset or sync button on the bottom of your mouse for a few seconds, so that the receiver can synchronize with your mouse. Mouse should now work OK
Jan 04, 2011 | Logitech Cordless Mouse
Tried to plug in wireless mouse would not come on, does the touch pad need to be off both of the usb ports not working, seems strange that both would not work at the same time.
First ensure that the usb is the appropriate dungle for the mouse, not just any usb will work for it.
When you get the the wireless mouse it comes with a dungle that you are to connect to the laptop.
If the mouse falls or hit a hard object, it might get damaged and wont work.
Try to use a new wireless mouse on your laptop to see if it works. if it does, then the fault is from your former mouse.
Try to use the old mouse on another system, if it does not work, then you have to replace the mouse.
Take care
Jun 26, 2010 | HP Compaq Presario V2000 Notebook
I purchased a HP laptop, Windows 7. I installed
You have to install the software that came with the wireless mouse. I have several, and some will and others won't work without the software. That is 90% what it is.
May 17, 2010 | Logitech Cordless Mouse
I can't get my new wireless mouse to work with my laptop.
Some wireless mice have a tiny switch on the bottom
Apr 17, 2010 | GE Wireless Optical Mouse
Wireless Mouse on a laptop with built inTouchpad on the keyboard
No need to disable the touchpad they should both work at the same time. Have you tried both the mice on another PC?. The first mouse should have the correct software already installed but you will most probably need to install software for the microsoft mouse. I hope you have tried resetting by hitting the button on the receiver then while its flashing the button on bottom of the mouse? If all this fails do have any other USB devices you can test on laptop?......good luck
PS I hope its not the batteries
Oct 31, 2009 | Microsoft Wireless Notebook Optical Mouse...
Connection procedure for Toshiba N745 mouse needed.
I don't know if this is the same as my mouse. However I have a satellite1955-S803 with wireless detachable keyboard and full sized optical wireless mouse. The original owner said it came with the laptop.
First I tried very hard to get the keyboard working. After a frustrating day of calling Toshiba, I noticed the "detachable" latches. I removed the keyboard to find a battery compartment. 4 days go by with me calling Toshiba trying to get a replacement. Finally found a battery at batteries plus that does work. about half the mAhr of the original but hey it works.
Now to the mouse. Replaced the AA's batteries but couldn't tie the mouse to the computer. I run linux so no M$ driver would help. Finally found a PDF of the manual and it says "if the mouse has trouble activating, press the wireless mouse button on the laptop."
That button is on the front left edge of the laptop (where the "Intel inside", "XP loaded", and "nvidia" stickers are located ) just to the left of the front silver "mode" button. Under the mouse press the connect button. (round near the optic laser but un-labled) then press the wireless mouse button on the computer and there you go. It just connects and works.
2 weeks I looked for this and it was just that simple.
Aug 26, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
How do i get my wireless mouse to connect with my laptop
Do you have a wireless keyboard also. It may be the reciever.
Apr 06, 2009 | Dynex Wireless Optical Laptop Mouse...
Belkin F8E825 USB Mini Wireless Optical Mouse Logo
406 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
