The machine gets hot while embroidering and freezes. sometimes it keeps sewing in the same place, the next it freezes up and i have to shut the machine off and on for it to work. it is less then three years old with minimal usage. also a few days ago the screen went completely blank and then turned itself back on.
There are 3 main fixes for a freezing SE.
1> Have the latest 12501 update installed, the 12124 had a problem.
2> make sure you have the right hook (the 2 older hooks have this problem.
3> The newer tension assembly with the grounding strap needs to be in the SE as well.
4> there were only suppose to be 3 but if your screen gets weird when it freezes, it could be the video transformer
Mine ended up being the power source to my machine was not working properly. It was replaced and now it is working fine.
I am having the same problem. Mine is just shutting off in the middle of either embroidering or just regular sewing. I have a call into my service center, but havent found anything out yet. Was wondering if you had? I did read on their site that there is a recall on the power supply, and must be replaced, and I dont know if mine has been replaced or not.
