Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water pumping out as trying to fill for rinse cycle
  • Whirlpool Master
  • 3,361 Answers
Sounds like your drain line is too low or no air gap in the drain outlet.
Posted on Mar 04, 2009
Water fills 20" on was cycle, rinse cycle fills 8". Clothes coming out soapy or really wet
it indicates that the pump is not getting power when on the spin cycle
it could be a blocked hose to the pump, faulty pump( obstruction in impeller of pump) or failed program board not connecting the spin cycle to the pump and water control solenoid.
best have a service technician check it out.
Jul 09, 2015 | Washing Machines
Gets stock in rinse cycle
Rinse cycles are usually with cold water. If it cant fill with cold water, it wont go through the rinse cycle. Make sure it fills with cold on a normal wash. You may find its filling with hot only. Alternatively, the machine may not be pumping out properly, this will cause a similar fault. Check to see the machine is draining at the end of the wash. check the pump and the filters for blockages or lint etc clogging the hoses or pump.
Feb 18, 2015 | Washing Machines
Why won't my washer fill up with water on the rinse cycle?
something hindering the rinse cycle? bad water pump or clogged pump?
Dec 20, 2014 | Admiral Washing Machines
I have Hobard LXIH dishwasher, it is working OK but during rinse cycle instead of taking in rinse agent it is actually fill rinse bottle back with water. Rinse pump is working, it was replaced in June
Check the rinse pump. The tubing needs to come from the supply into the bottom of the pump, and the pump should be running clockwise. If the pump tube is worn, the rinse pressure will blow through the pump filling the bottle
Dec 12, 2013 | Hobart Dishwashers
Not pumping out water on rinse cycle
i suspect the main board providing the pump is not jammed and not burnt out . if you have a jammed or a burnt out pump it can cause the main board to fail and replacing the pump will not fix the problem. Try a new board
Nov 28, 2011 | Fisher and Paykel Washing Machines
After rinse fill the pump will not start
Hello, is there water in the bottom of your dishwasher? If there is water in bottom. Then try running the dishwasher throught another washing cycle. Now, if there is not water in the bottom of your dishwasher. Then the dishwasher has finished its washing cycle, rinsing the cleaned dishes. GB...stewbison
Sep 17, 2011 | Dishwashers
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Will only work on cycle, will not agitate in the other cycles
Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal De
