Question about Boating
Accelerator handle slips back
I have an Evinrude 9.9 two cycle, 1996 that I use on my sailboat.
The when I turn the handle to accelerate, if I let go it slips back to a lower speed; it just doesn't stay where I leave it.
I bought a manual to fix, but found nothing in the whole manual!
  • 257 Answers
Hi, It is a safety device. These small motors are equipped with a spring to return the motor to idle speed when you let go. You can ( and I am not advising you to do this) remove the spring so that the handle stays put when you let go. This should Fixya!
Posted on Mar 03, 2009
How to remove the twist grip on 15hp evinrude outboard motor?
Fix Tiller Handle on 15hp Evinrude - YouTube
? 2:02
www.youtube.com/watch?v=dl0b7WFKsjc
Mar 30, 2011 - Uploaded by Budnipper82 Evinrude 15 HP gear removal - Duration: 9:11. by kodibass 7,404 views. 9:11. Repairing an Evinrude 9.9 ..
Nov 01, 2015 | Boating
1996 Toyota Camry, manual transmission. Car is bucking when accelerating, esp. Between 2nd and 3rd gear.
start by first checking your cars motor and tranny mounts sounds like the transmission is moving back and fourth as you accelerate and shift gears maybe due to a broken mount or more than one, hope that helps try there first. Broken Rear Engine Mount Camry V6 heres a link on youtube check it out good luck
Mar 29, 2015 | 1996 Toyota Camry
I've recently noticed that my 1996 v6 vs commodore has a high pitch squeal while accelerating and there seems to be no power behind it anymore either.
I would suggest that you check all units being driven by the belt as the squeal is from something not turning freely and making the belt slip on the crankshaft pulley or slip over what is seizing up.
Jul 26, 2014 | Cars & Trucks
1996 Rav4 slips out of 5th when accelerating garage how told me have to take gearbox out and send it away very expensive! Please can u advise
if it slips out of 5th on accelation ,chances are the phos bronze ring that guides it into mesh needs replacement,there is no point in just taking the thing apart and repairing same unless you can diy.can you not check out yellow pages for a gearbox reconditioner.....maybe cheaper.or you could hold the gearstick while you are accelerating???maybe not...
Sep 09, 2010 | 1996 Toyota RAV4
Whenever I turn left and accelerate quickly, the transmission seems to "slip". It does not do that when I accelerate and turn right. Any ideas?
Have you checked the fluid level. It will do this when it's low. The fluid runs away from the filter pick-up.
Apr 13, 2010 | 1996 Pontiac Grand Prix
Slipping in first gear - 1996 Kawasaki Vulcan VN1500
only two things going on here, first the clutch is out of adjustment, no enough free play, the next is the clutch plates and springs need replacing.
Sep 15, 2009 | 1996 kawasaki VN 800 Vulcan Classic
Acceleration
Your clutch is goin g out on it.
Jun 29, 2009 | 1996 Volkswagen Jetta
Accelerating problem with my 1.6 ford escort automatic
I have the same car,,i think your automatic transmission is slipping,(check fluid),or if its a manual transmission,then your clutch is worn out.(replace)
Jan 19, 2009 | 1996 Ford Escort 4 Door
1996 chevy K1500 transfer case slipping out of 4 wheel drive
Your trouble is most likely not in the transfer case but in the front differential engagement solenoid.
Dec 20, 2008 | 1996 Chevrolet K1500
RPms increases as im driving or when I let go the accelerator
it sounds like your transmission is slipping check fluid level and look into a service. if not that you might have a bad trans
Nov 13, 2008 | 1992 Honda Accord
Boating Logo
133 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
