Question about Panasonic Workio DP-2330 Printer
Cleared a paper jam from DP 2500, but it still says "clear paper"
Message is J33, shoes a jam in 2 places, but there is no more jam, can I reset the machine. We have rebooted it twice and the same jam messge comes up agaim.
4 Suggested Answers
MitchSchaft
  • 24 Answers
SOURCE: getting J33 code on panasonic workio dp-2500
That's a registration sensor error. 9 times out of 10, the registration sensor's spring fell out of place and that sensor is not popping back. When you open the right door, you'll see a sensor flag (plastic flag) sitting in the middle of a rubber roller.
Posted on Jan 25, 2008
  • 100 Answers
SOURCE: panasonic workio dp-1810p
pls check out the sensor lever below the drum if it is freely moving.
because that is the sensor concerned for j33
Posted on Aug 21, 2008
  • 224 Answers
SOURCE: PANASONIC DP-C262 COPIER IS SAYING THERE IS STILL
the diagram will show where it is but refer to user manual. if no paper then a sensor has become dislodged and will need to be reseated
Posted on Mar 30, 2010
  • 224 Answers
SOURCE: Panasonic DP 2500 photocopy machine from you a few
the top cover that opens to the left normally has a small piece of plastic that slots into a sensor toward the back of the adf. this small piece has broken off so the machine thinks the adf is open. an engineer would need to replace the door for you.
Posted on Jul 23, 2010
Paper jam cleared no tears message still appearing clear paper jam than pressk OK have open the printer checked thoroughly turned off 8 times and on again. No paper jams all cleared.
When you turn off the printer unplug it from power and the computer for a few minutes. Plug only the power back in and turn it on. Also consult the manual to find out how to "reset" your printer.
Hope this helps
Mar 08, 2011 | HP Photosmart D5360 InkJet Printer
Panasonic DP 2500 photocopy machine from you a few months ago. I cleared a few paper jams and have not had a problem until now. The message on the machine says to ?close the ADF cover?. I do not know what...
Jul 22, 2010 | Panasonic Workio DP-2500E Copier
Panasonic Workio DP-2000 j33 problem
The sensor arm just below the registration roller has dropped the spring to return it to it's home position.
Mar 27, 2009 | Panasonic Workio DP-2000P Copier
Paper jam message
Look for little pieces of paper that get stuck in the rollers, also verify that the gears and roller didn't get misaligned when you cleared the jam.
Good Luck,
Mar 02, 2009 | Canon MX310 Office All-In-One Printer
Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Jan 04, 2009 | Canon MP610 Photo All-In-One Printer
I had a paper jam on my brother mfc 420cn printer. I cleared the jam, but the error message will not clear. I unplugged the printer and turned it back on but the message was still there. Is there a...
This indicates the jam is not clear. Please check all areas including the removable cover on the back (by pinching the 2 squeezable tabs) and pulling out.
Jan 13, 2008 | Computers & Internet
Paper jam won't clear
Look for a small piece of paper remaining in the machine.
Also there may be a jam switch actuator that has fallen off.
Dec 07, 2007 | Panasonic Workio DP-2310 All-In-One Laser...
Getting J33 code on panasonic workio dp-2500
Nov 16, 2007 | Panasonic Workio DP-2500E Copier
Panasonic workio dp-1810p
Sep 01, 2007 | Panasonic DP-1810P Laser Printer
Panasonic Workio DP-2330 Printer Logo
80 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
