I was printing and my printer was running out of ink so i shut off the printer after that my printer says off line and will not print.please help
Make sure the printer is back on. Go to control panel, printers. Right click your printer, on the sub menu that appears, click 'use printer offline' to remove the check mark. That should do it.
Posted on Mar 03, 2009
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .Use the test print to calbrate the SCANNER.
Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Sep 02, 2011 | HP C4680 All-In-One Inkjet Printer
Jul 13, 2008 | HP Office Equipment & Supplies
Jul 08, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Mar 08, 2010 | HP LaserJet 1000 Printer
Aug 19, 2009 | HP Officejet 5610 All-In-One InkJet...
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Jul 14, 2008 | Brother Multi-Function Center MFC-240C...
May 08, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Mar 30, 2008 | Canon BJC 3010 InkJet Printer
Jan 11, 2008 | Epson CX4200 All-In-One PSC Printer
Sep 01, 2015 | Acer Aspire 5315 Notebook
138 people viewed this question
i tried the solution you sent but it did not work.i refilled the cartridge. the printer is a copier also so i tried too make a copy and it woks fine just to do copies.thank you for helping
Could you please explain with a little more detail? did you replace the ink cartridge with a new one(or refilled it)?
