Question about Espresso RMI La Cimbali Espresso Machine
Stripped shower screen threads.
Hey.  My staff and I have stripped out the inside threads of the shower screen screw in the group head assembly.  Do I need to purchase a whole new group head assembly?  We typically unscrew the screens once or twice daily to clean the screen of grinds and are constantly stripping the screw heads themselves, but this is the first I've heard of the inside stripping out.  The supply place says they have to sell me a litany of parts.  Do you have a link to a diagram?  I have an M28 fully manual and there's no manual I can find anywhere.
    President:
  • 1,618 Answers
No the only thing you need is the head, if you take a close look at the head you will notice the 3 bolts sometimes allen wrench screws around stainless head, that does not need to be replaced, the diffuser which sits above the shower screen does not need to be replaced, the pipe fittings that connect to the boiler does not need to be replaced. The only thing you need is the head the exchanger gaskets and you can always go to Lowes or Home depot or Ace for the Stainless steel nust and locknut washers on the boiler. If you doing it yourself it will take you a full day to replace it.
Posted on Mar 26, 2009
    Novelist:
  • 137 Answers
Take group head to metal workery, drill biger hole and make one part from bras for there
the part must have hole with unstriped screw teeth in center. to block unscrewing the biger part you must open hole in border of head and brass part then you put one safety screw there(must be inox).
i hope you are content with solution.
Any ideas on how to remove a stripped screw from lawn mower, Briggs and Stratton, top plate, there are 3 screws and one is stripped not allowing the cover to come off
By stripped, do you mean the head is stripped, or are the threads stripped.
Head stripped = Damaged Screw Extractor Drill Bits 4 in 1 Bolt Extractor Set Easy Out...
Stripped threads = You need to "drill off" the head of the stripped screw. Get a sharp drill bit that is at least twice the size of the threads. Drill into the screw head until the entire head is gone or can be removed..Once the entire head is gone, you should be able to remove the cover..once the cover is off, you should be able to remove the screw with vise grips or other suitable tools.
Jul 08, 2017 | Briggs Garden
Hi, everyone! I've been trying to repair my Mom's 2004 Bissell Powerlifter (i.e., "the maroon one") for the past month or so, as it had quit spraying solution about a year ago. After reading many of the...
Not sure what you mean by "stripped". Do you mean the threads, or the Phillips head?
If the threads are stripped, then it's safe to assume it's not gripping very well and you might be able to *carefully* pry the housing apart with the screw still in place.
If the Phillips head is stripped (screwdriver won't grip) then it's a different ball game. Drilling the head off is one way, but if your drill is even slightly off-center it won't work and you'll end up drilling the housing.
If you can't drill it, then there's only one thing left that I can think of, and that's to cut through the screw at the housing joint line. Use a very fine tooth hacksaw blade in a holder like the one pictured. Use a shallow angle while sawing so you don't damage anything inside. Doing this will leave a slot in the housing, but you can tape over it on re-assembly.
May 18, 2014 | Bissell Vacuums
Undo stripped screw on rear light panel
Stripped head or threading on screw itself?
Nov 09, 2013 | Land Rover Cars & Trucks
Sliding holder for hand held shower head slips on mounting rod - loose
The locking screw, if that's what it is, may have stripped threads.
Jun 07, 2017 | Grohe Home
Spark plug tube striped spark plug jumped out of tube
The issue seems to be related to the spark plug threads. The spark plug is either not tightened down or the threads are stripped, and during the compression stroke when pressure is applied inside the combustion chamber, the pressure leaks thru the spark plug threads and blows off the spark plug boot. If the spark plug is not tightened and the threads are ok, then tightening the plug will resolve this issue. If the spark plug threads are damaged, then the threads will need to be repaired, and will require the cylinder head to be removed to repair the stripped threads. Taking the cylinder head off requires the engine's top end to be ripped apart and re-assembled....big job.
Nov 26, 2010 | 2004 Dodge Stratus
I tried to remove the fixing screw on a grohe ladylux kitchen faucet and I could not get it out with an allen wrench. In the process of trying to get the fixing screw out I stripped the screw. Any...
I am having the same problem. The outer hex head is not defined enough to get a grip on it (tried with needle nose pliers and was not able to turn it) and the interior allan mold has been rounded off making the allan wrench useless. How do I get this screw out so I can proceed with replacing the cartridge?
Nov 12, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
Best way to remove a stripped set screw from the handle
drill it out, use a bit that is smaller than the threaded part of the screw and use oil on the bit to prevent over heating
Mar 21, 2010 | Moen & Bayhill& Single Handle Tub & Shower...
I have a WaterPik shower head that keeps coming
If your unit has a threaded connection for the handle and hose the threads are most likely stripped. You can get thread grip material at most hardware stores and repair it yourself. Otherwise replacement is necessary.
Feb 21, 2010 | Water Pik Shower Head
2000 Neon hasn't had the air filter changed in at least 2 years because the one of the screws that holds it in has the top of it stripped. Can anyone recommend how to solve this issue without costing an...
Is possible, on your Neon to remove the entire air cleaner assembly? If you can get the assembly out on work bench maybe you can get on it with a "Vise-Grip" (locking plier) and get it out. Or take electric drill and drill the bolt out and replace it with new. When you say it's stripped do you mean the threads are stipped and it spins but won't come out? Or, is the head of the bolt or screw stripped out and the wrench or screwdriver won't grab it? If you do get it apart make sure you put some grease or anti-sieze compound on the threads of the bolts so they won't rust in. Good luck!
Dec 08, 2009 | 2000 Dodge Neon
My bunn coffee's spray head does'nt stay screwed in, i've lost 2?
likely the threads are stripped in the shower head, get a new one from bunn, or an appliance store
Dec 10, 2008 | Bunn NHB Coffee Maker
Espresso RMI La Cimbali Espresso Machine Logo
349 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Mohamed Ismail
Mohamed Ismail
John
Mark Cheong
Mark Cheong
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
