Question about Dell Dimension 2400 PC Desktop
Unable to boot up - NIC failure message appears when attempting to startup. Can't start in Safe mode
  • jtibb Mar 04, 2009
    Thanks, we were able to re-boot, but we're not able to connect to the internet now. I'm wondering if we fried something.
    Scholar:
  • 155 Answers
Try to change the boot sequence or set your bios to defaults. Restart the computer. tap f2 on the dell logo. Press alt and F together. press alt and B together. Press Y if you get a prompt to 'save changes and exit?'.
If it still doesnt work. go back to the bios. restart. tap f2 on the dell logo. go to 'Integrated devices'. disable the network interface card'. Press Alt and b together. then try to boot the computer. Pls post back if it works.
Posted on Mar 03, 2009
    Genius:
  • 1,066 Answers
Dont disable the network card, remove and /or replace it.
Posted on Mar 07, 2009
Will not boot to safe mode imac g4
Starting up in Safe Mode Follow these steps to start up into Safe Mode.
  1. Be sure your Mac is shut down.
  2. Press the power button.
  3. Immediately after you hear the startup sound, press and hold the Shift key. The Shift key should be pressed as soon as possible after startup, but not before the startup sound.
  4. Release the Shift key when you see the Apple logo appear on the screen.
After the Apple logo appears, it may take longer than usual to reach the login screen. This is because your computer is performing a directory check as part of Safe Mode.
To leave Safe Mode, restart your computer without pressing any keys during startup.
Sep 25, 2014 | Apple Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
How to get to safe modem?
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use yourarrow keys to move to "Safe Mode" and press your Enter key.
Trouble Getting into Windows 2000 or Windows XP Safe mode- If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen
Jan 14, 2012 | Compaq Armada M700 Notebook
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Everytime i boot up i get an error message stating that there was a boot failure and it loads in safe mode then it prompts me to buy some software to repair my netbook
Sounds like a combination of 2 things.
  1. Machine has contracted a virus.... On startup, the machine would never prompt you to buy anything unless it's infected with a virus or malware.
  2. Corrupted bootlog....Any boot failure is usually due to a corrupted bootlog. This can be for a variety of reasons ie improper shutdown, bad battery, or what I think is the case here is a virus or malware.
If possible, boot directly into safe mode (tapping F5 key while booting). From there you can try different options ie Last known good configuration, run memory test, system restore. If you can't run your anti-virus package in safe mode, you may need to attempt a system restore, preferably to a point just prior to where you picked up the virus.
Jul 09, 2011 | Computers & Internet
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
I have a G5 2.3 dual core running 10.4 I need to repair the system but have lost my install disc. Do you know where I can get one? Roderick Duncan
To start up in Safe Mode, hold down the shift key and then startyour Mac. Safe Mode takes a while, so don’t be alarmed when you don’tsee the desktop right away. While you’re waiting, the operating systemis verifying the directory structure of your startup volume, andrepairing it, if necessary. It will also delete some of the startupcaches that may also be preventing your Mac from starting successfully.
Once the desktop appears, you can access and run disk utility http://macs.about.com/od/applications/ss/firstaid.htm tool just as you normally would. When First Aid is finished, restart your Mac normally.
Please note that not all applications and OS X features will workwhen you boot into Safe Mode. You should use this startup mode only fortroubleshooting and not for running day-to-day applications.
Boot Into Single User Mode Start up your Mac and immediately hold down the command key plus theletter ‘s’ key (command + s). Your Mac will start up in a specialenvironment that looks like an old-fashioned command line interface(because that’s exactly what it is).
At the command line prompt, type the following:
/sbin/fsck –fyPress return or enter after you type the above line. Fsck will startand display status messages about your startup disk. When it finallyfinishes (this can take a while), you will see one of two messages. Thefirst indicates that no problems were found.
** The volume xxxx appears to be OK.The second message indicates that problems were encountered and fsck attempted to correct the errors on your hard drive.
Sep 30, 2009 | Apple Power Mac G5 Desktop
Problem not fix
Boot the machine in safe mode, then reboot as normal, if the problem persists after reboot did you
install software proir to this try reinstall. Use anti virus and spyware malware scans etc.
Running in safe mode, is exactly that safe while most problems exist in OS.
Let me know how you get on.
Jun 10, 2009 | Dell Inspiron 6000 Notebook
Computer will not boot up. I have tried to boot up in safe mode, normal, safe mode with prompt command...nothing works, just goes back to the normal start up screen and keeps doing the normal start up over...
It looks like you're encountering an endless reboot? Here's what to do to find the actual error message.
  1. Turn on the computer, and press F8 after the POST screen but before Windows attempts to start to access the advanced startup options.
  2. Select "Disable Automatic Restart On System Failure" and press Enter.
You should now get a blue screen with an error message and error codes. Please write these codes down and report back.
Mar 24, 2009 | HP Compaq Presario SR1830NX PC Desktop
Laptop Startup
hi dear
oh so sorry to hear that
this methode for windows Xp
and let try this
Microsoft Windows Vista users Tip: If you are running Safe Mode because you cannot get into Windows you may want to first try loading the last known good configuration. Additional information about this mode can be found on document CH000626
To get into the Windows Vista Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Debugging Mode
Disable Driver Signature Enforcment
ok
cropp
Mar 19, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
2,274 people viewed this question
Alun Cox
