Question about LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television
LG RU44SZ51D halogen bulb
Has anyone changed the bulb in their LG RU44SZ51D projection DLP TV. We were watching last night we heard a pop and the screen went black. We found out today that it is most likely the bulb since the TV was purchased in 2005 and not covered under the extended warranty. We found a place that sells bulbs we just need some direction in how to go about changing it ourselves.
SOURCE: RU52SZ30 Sucks
But a bad light bulb would not, as far as I can tell, cause the redness. When yours went, what if anything was left on the screen? Thanks.
Posted on Nov 30, 2007
SOURCE: Red screen on LG 44-inch DLP
Rear projection TVs require a light bulb (found on the right hand side of TV behind a small screw fixed panel) and this, like any bulb needs replacing from time to time. You need to get it changed by a repair guy or get a bulb yourself and do it. They're quite expensive though, £200 last I heard I think.
Posted on Oct 06, 2008
SOURCE: changing lamp on lg dlp
On my unit there's a panel on the lower right hand side, remove the 2 screws with a screw driver. Inside you should see a compartment that is metal and has a thin metal handle. Remove the Black screw on the top left hand side. Then pull the unit out with the handle. Inside the unit holds the bulb, just replace and go through these steps in reverse to place back together.
Posted on Oct 25, 2008
SOURCE: 42 inch LG Plasma TV - Lost picture
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Posted on Jan 30, 2009
  • 13 Answers
SOURCE: how to reset after replacing bulb
mute on remote+ok on tv panel at the same time
Posted on Feb 02, 2009
Good morning Sam. Last night while watching TV the
Hello Andrew, Could I get you to please post the model number and make of the set. I will be better able to assist you.
Dec 03, 2011 | Samsung 56" Slim-Depth LED DLP HDTV
We heard a loud pop and the tv turned off and
That sounds like the lamp bulb blew and you will need to replace it. You can find ads on this web site that sell DLP bulbs at a decent price and you can install it yourself, or you can call 1-800-samsung to find the nearest service center.
Jul 16, 2010 | Samsung HCM4215W 42" Rear Projection...
LG 50" 2 1/2 yrs old. Watching it last night and there was a pop (like a light bulb breaking) and now tv does not work. please help
it is probably a dlp and it has a lamp in it. You can replace the lamp yourself just be careful when changing it that you do not touch the lamp itself. If you have the owners manual it should tell you how to change it.
Aug 10, 2009 | Televison & Video
Replace projection bulb in our LG TV Model RU44SZ51D.
There is an access door on the back with four screws, then the lamp inside has 2 screws and then will slide out. Most places will sell you just the raw bulb, not the whole lamp assembly, so this is a little harder to change. If you can find the whole lamp assembly you can easily change this yourself.
May 26, 2009 | Televison & Video
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
Apr 22, 2009 | Televison & Video
Blue dots and blue screen on Hitatchi 50"
Bad Light Engine Call UED for rebulit one 1-800-648-6657 They are not cheap.
Dec 26, 2008 | LG RU-44SZ51D 44" Rear Projection...
Go to this site, follow the instructions, and it might fix your problems. I did, and my tv is better than ever!
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Mar 28, 2008 | LG RU-44SZ51D 44" Rear Projection...
Toshiba 42 in 720 DLP TV MODEL HM66
You need to replace the lamp in this set. The "pop" you heard was the lamp popping.
Josh
Feb 24, 2008 | Toshiba 42HM66 42" Projection HDTV
Sony Grand WEGA KF50WE610 50 in. Rear Projection HDTV ready
Your projector bulb burned out, easy to replace yourself
Oct 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Open Questions:
LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television Logo
85 people viewed this question
Computer Repairing
Computer Repairing
